z85 leafs install on 2000 jimmy issue
i installed a set of rear z85 leafs onto my gmc jimmy 4 door. my problems are now that its lifted the back up high causing my factory emergency brake on the driver side to be to short since its lifted more and my axles moved back a little bit. sencond issue is i have the springs installed right but with 2 inch lift shackles and my shackles almost rub up against my rear trailer hitch has any one had this issue before
they were pulled from the wreckers from a 96 s10 pick up.there were used but had a leaf added and were in great shape. now when the truck is on the ground the shackles almost hit my rear trailer hitch and my ebrake cable dont strech far enough
i figured they had a diffrent offest and they seem longer as well. would a s10 drive shaft correct the issue that i pulled the springs from originally?
musclemasterflex
Sep 13, 2011 09:29 AM
musclemasterflex
Suspension Tech
Aug 26, 2011 09:10 AM
S10 TrailBlazer
Sep 30, 2010 12:39 PM
