zr2 axle swap cv question
Old Oct 29, 2013 | 01:39 PM
warthogdriver's Avatar
Thanks for the tips guys...yeah no local yards around me even have any zr2 axles....drudging craigslist for a part out maybe. Will keep my eyes open. I should have gotten on this over the summer..but life keeps moving.
Old Oct 29, 2013 | 02:11 PM
Jamaroon's Avatar
I can't remember if you've done it or not, but now would be a good time for the bravada shaft and tube as well. I want to try and find one before I put the iron diff into the blazer.
Old Oct 30, 2013 | 06:18 AM
ecksrichecks's Avatar
ecksrichecks is on a distinguished road
Originally Posted by warthogdriver
Cost. Can do an axle swap myself...gears not so much.
Fair enough. I think I'd rather fresh gears, just me tho. I'm not that mechanically inclines, so either way it's going to my buddies shop.
Good to find out I can just swap the gears out and the cv shafts are still good to use.
Old Oct 30, 2013 | 06:37 AM
from what i gather with the front i just need the diff...and i keep my axle tubes?
good point on bravada swap....forgot about that.
Old Oct 30, 2013 | 07:55 AM
Jamaroon's Avatar
There's only the one tube on the pass side.
If you're keeping the axle disconnect, I'm sure you'd get the diff and tube all together, in which case I'd just swap the whole thing. Less hassle IMO. But if you are able to get just the diff, then yes you can swap your tube over to the new diff.
If you're going to switch to the bravada shaft then you would switch out the tube for the bravada one.
Old Oct 30, 2013 | 10:34 AM
Diaita's Avatar
Originally Posted by Jamaroon
I have one ..... and flares
Me too! Neither are ZR2 mind you...
Old Nov 9, 2013 | 07:27 AM
Blazer2005's Avatar
Blazer2005 is on a distinguished road
Would the zr2 cv shafts fit on a normal s-series
Front diff or would I have to do a whole axle swap? And
Since the shafts are longer would I have to get the upper
And lower A-arms off a zr2 also?
Old Nov 9, 2013 | 09:13 AM
El_Beautor's Avatar
You can't use ZR2 CV shafts on a normal Blazer. It's not the control arms that make it wider, it's the frame. The frame is shaped differently on the ZR2's and the mounting points for the control arms are lower and are extended further out from the center line of the Blazer.
goldnugget
Feb 25, 2022 09:56 AM
Blade_24k
Suspension Tech
Apr 21, 2012 11:27 PM
ImScrewed92
Nov 12, 2010 09:44 PM
jimmy1996
Oct 25, 2009 10:51 PM
W2JGA
Mar 19, 2009 02:32 AM
