Zr2 cv joints in non Zr2
Old Jun 21, 2012 | 06:07 PM
Jase1979's Avatar
Jase1979 is on a distinguished road
Default Zr2 cv joints in non Zr2
Is there any benefit to installing a Zr2 cv axle in a non Zr2 that has been lifted? I noticed the Zr2 axle is 1/4" longer and was wondering if it would be a benefit seeing as how I need to replace both front axles and they are only $2 in the difference
Old Jun 21, 2012 | 06:32 PM
war00's Avatar
war00 is on a distinguished road
its worth trying to see if they will fit if not return them and get the other ones. let us no how it works out.
Old Jun 21, 2012 | 08:46 PM
Private_Ops's Avatar
Private_Ops is an unknown quantity at this point
Pretty sure a Z CV shaft is more than a 1/4" longer than a non Z. You could try but i dont think they'll work.
Old Jun 21, 2012 | 08:57 PM
They won't fit, too long.
Old Jun 22, 2012 | 03:41 PM
Jase1979's Avatar
The napa site actually gives you the length measurements and it is only a 1/4" longer. Sucks they won't fit thought it might help out with the cv angles and possible cv boot slippage problem, oh well cost money to play 2 stock axles it is!
Old Jun 22, 2012 | 04:16 PM
warthogdriver's Avatar
for the boot slippage i just used two large adjustable clamps...been on there for years...no issues since i did it.
Old Jun 25, 2012 | 04:33 PM
Jase1979's Avatar
Do you still have the factory plastic boots on your axles with the gear clamps?
Old Jun 25, 2012 | 07:01 PM
the outer boots are factory clamped.
the boots that slipped were the inner near the diff.
the clamps went on at the end of the boots closest to the diff on both driver and pass side.
here is a thread on the slippage issue
https://blazerforum.com/forum/steeri...t-crank-35874/
Old Jun 25, 2012 | 07:49 PM
Jase1979's Avatar
Sweet, Thanks for the help, will get some clamps in the morning
Old Jun 25, 2012 | 07:51 PM
Dont forget the lube packs if the boot spun out any lube.
And wipe down all the surfaces for a good seal...and dont over tighten them.
litterbug
Lifting Tech
Apr 8, 2011 10:47 PM
Bberry20
Feb 25, 2010 09:28 PM
Spectreblazer
Feb 13, 2010 04:59 PM
Logan
36
Dec 6, 2009 07:41 PM
Logan
Lifting Tech
Sep 18, 2008 11:44 AM
