Suspension Tech Have a question about modifying your suspension? Ask it here.
03 BlAzer LS suspension swap to ZR2 suspension?
Old May 31, 2020 | 12:38 PM
Zelmer Joseph's Avatar
Zelmer Joseph is on a distinguished road
Default 03 BlAzer LS suspension swap to ZR2 suspension?
2003 Blazer LS 4 doorhas a lot of of suspension work to do and I'm wondering if I can upgrade to the ZR2 suspension. Is there anyone who knows how to/ and whether or not it's easily done?
Thanks in advance guys.
Old May 31, 2020 | 02:54 PM
There is someone here who is doing exactly this. I think they had to get a ZR2 donor vehicle to do it right. The front suspension components for the ZR2 apparently don't just bolt on. They also have different rear springs and torsion bars.
And then if you get the larger rear axle with the lower gears (higher ratio like 4.11:1), you will have to get a front IFS with the same gears. The lower gearing is necessary if you are to run the 31" tires because the larger the tire, the higher the effective gearing.
This is why I will likely not go to any larger than my 30" tires with my 3.73:1 gears. With the larger tires compared to the stock 235/70 R15s, my 3.73:1 gearing is now more like 3.48:1. https://tiresize.com/gear-ratio-calculator/
Old May 31, 2020 | 08:15 PM
I myself am doing this, not as into as others, but it "should" come out the "same".
I already have a 2.5 rough country lift with an add-a-leaf.
I am only putting in the rear axle and front diff.
I am measuring the rear leafs while the axles are out to see if it will be a "direct swap". But as in a recent thread, i believe it went right in. The front end has different mount locations, so would need to cut and weld those locations, and I can double check about CA sizes... I need to get the sway bar and mounts off them anyways... I'll be welding them on.
edit: I have a 99 but suspension is the same
Clann91
Suspension Tech
14
Dec 23, 2012 12:23 AM
opensesame
Apr 7, 2011 09:11 AM
ChevyMan90
Suspension Tech
Sep 24, 2009 10:25 PM
blkblazer
May 16, 2009 01:31 PM
livinterror
Dec 28, 2008 01:27 PM
