Suspension Tech Have a question about modifying your suspension? Ask it here.
Ls-zr2
Old May 10, 2011 | 02:34 AM
Clann91's Avatar
Clann91 is on a distinguished road
Exclamation Ls-zr2
I have a '98 Blazer LS Vortec V6 with the stock suspension. I really want to put a ZR2 suspension on it but I'm not sure where to go to get this done as far as purchasing goes. Any help is appreciated. If I can get some pricing too that would be awesome.
Old May 10, 2011 | 08:42 AM
mov4x4's Avatar
mov4x4 is on a distinguished road
You can go to your local junkyard/s and see if they have any ZR2's that have everything your looking for.
Old Jun 17, 2011 | 07:09 PM
rodono's Avatar
rodono is on a distinguished road
zr2 suspension wont give you any lift. most zr2 parts are the same as non zr2
Old Jun 17, 2011 | 07:12 PM
rodono's Avatar
the only things that are diffrent are really, leaf springs and torsion bars for the suspension
Old Jun 18, 2011 | 08:33 PM
zr2dan's Avatar
zr2dan is on a distinguished road
hey buddy zr2s have bilstein shocks different leafs and a wider stance also skid plates and alot of the other parts have to be different also because you have to order parts zr2 specific overall they set 2inches higher and wider and they also have a lower geared diffs 3:83s instead of 3:73s
Old Sep 7, 2011 | 09:58 PM
jaked up's Avatar
jaked up is on a distinguished road
as zr2 dan said well more in a nut shell is that zr2 parts wont fit on an ls also take it from me (i tryed to put zr2 parts on my ls) the frames are different not only are the wider but also stuff like the a-arm tabs are different and the leafs are longer then the ones in the ls
Old Sep 8, 2011 | 12:51 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Short answer is no you cant do this.. but if you really wanted to spend alot of money and have all the mods done to your frame could be done, but not at all worth it. i asked this question a while ago and and the answer i got is that the way the ZR2 suspension mounts up to the frame is completely different than a regular blazer. i thought the only parts you could take from a ZR2 and put on a normal blazer without mods where the leafs but according to jacked up that would be wrong and he is probably right.
Old Sep 8, 2011 | 11:15 AM
tibby's Avatar
Default .
If your trying to be more like a zr2, goto the yard and find a zr2 and get the axle's off, fender flares, and then buy either a body lift or suspension lift. That'll get your wider and taller stance. Just my .02.
Old Sep 11, 2011 | 09:02 PM
gofstcat's Avatar
gofstcat is on a distinguished road
i m not sure where u are but i just finished swaping my frame and running gear out for theZR2 set 3.73 gear from 3.42 stearing stab bigger sway bar 4 wheele disc brakes dule piston calipers ,ther is some work involved but worth it i got the frame from s10 depot in sarasota fl great people i have a stocl 97 frame with a 5 inch lift installed for sale CHEEP!
Old Dec 18, 2012 | 04:37 PM
SoullessNihilist's Avatar
SoullessNihilist is on a distinguished road
Default LS Body on ZR2 Frame?
Hey fellers, I have a question... I found a rolling chassis of a ZR2, will my engine, tranny/transfer case, body and everything else bolt right up to it? heres the kicker.. i have a 97 LS blazer, this ZR2 blazer chassis is a 99. i'd hate to throw $500 in the trash and rip my ride apart for nothing!
