Suspension Tech Have a question about modifying your suspension? Ask it here.
2' body lift
Old Jun 25, 2008 | 09:12 AM
ncmudblazer's Avatar
ncmudblazer is an unknown quantity at this point
Default 2' body lift
is there any other way to lift a blazer 2' without getting a body lift kit? a friend said he had a shackle lift on the back and turned some kind of rod to lift the front. any ideas?
Old Jun 25, 2008 | 09:40 AM
FFJustin99Chevy's Avatar
FFJustin99Chevy is an unknown quantity at this point
Default RE: 2' body lift
Yes, you can do that. Your friend is referring to the "torsion bars" on the front. Use the SEARCH function at the top of the screen and search "torsion bars" or "torsion crank". This topic has been discussed hundreds of times and Jigg did a 'Do It Yourself' on how to crank your torsion bars including pictures.
**Start looking here....
https://blazerforum.com/searchpro.as...p;timefilter=0
Old Feb 19, 2009 | 06:21 PM
sappers_21b_hooah's Avatar
sappers_21b_hooah is an unknown quantity at this point
has anyone had any problems or know any direct things ill need to modify when i put my 2" body lift on ?
Old Feb 19, 2009 | 07:48 PM
cr8390's Avatar
cr8390 is an unknown quantity at this point
like really? Digging up a random old thread and posting your problem..... Make a new thread about your problem
Old Feb 19, 2009 | 10:18 PM
Byte Stryke's Avatar
Byte Stryke is an unknown quantity at this point
ORIGINAL: sappers_21b_hooah
Depends really on which kit you get.
For Example my PA kit required some cutting in the rear bumper brackets.
and as far as posting to an old thread about a 2 inch lift... at least he looked first.
Old Feb 19, 2009 | 11:24 PM
bandidolenny's Avatar
Be sure to take your fan shroud apart before you start lifting... Actually be sure to read through the instructions before you do anything.
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
