Suspension Tech Have a question about modifying your suspension? Ask it here.
3" body lift
Old Aug 27, 2011 | 08:41 PM
88blazer4x4owner's Avatar
88blazer4x4owner is on a distinguished road
Default 3" body lift
Hi, i would like to put a three inch body lift on my truck and was wondering if I would need any thing else thats not included in this lift?
Summit Racing 7800000 Body Lift Kit 7850300 | eBay
Any problems with this lift?
Thank you
John
Old Jan 21, 2012 | 12:19 AM
jaked up's Avatar
jaked up is on a distinguished road
your going to have to extend almost all of your linkage
Old Jan 21, 2012 | 02:01 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
my friend did it to his 88 blazer without any problems. he said the 4x4 lever got pulled down quite a bit tho. and you will have to do something to your back bumper unless you want a gap
Old Jan 21, 2012 | 12:37 PM
neo71665's Avatar
Bumpers have to be raised. I have offroad bumpers so it was easy.
On my shifter I cut mine and extended it. Used a section of 1/2 inch imc electrical conduit. Used a welding rod for a new rod inside so the push button still worked. It needs A small bend to clear everything after its made longer but it works fine.
Old Jan 21, 2012 | 08:41 PM
duxtoyz's Avatar
duxtoyz is on a distinguished road
ul have to extend ur shifting linkage, drop ur oil filter, and make sure all ur lines under the drivers side dont get stretched. ul also have to extend ur fuel filler neck. and as for ur 4wd shifter, ul have to cut sum of the body from the bottom of the hole where it comes into the cab so u can put it in 4lo. otherwise its ez and needed for an s10....
Old Jan 22, 2012 | 04:01 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
If your going to do this I suggest putting a piece of steel in between every cab mount and lift block , to distribute the weight a little better . I did the 3 inch body lift to my 94 s10 blazer and all the cab mounts were in real good shape , but they pounded there way through pretty quick .
whitejimmy
Lifting Tech
22
Mar 8, 2010 02:50 PM
ComputerNerdBD
Feb 28, 2010 11:30 AM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
cide
Mar 23, 2009 10:57 AM
