Suspension Tech Have a question about modifying your suspension? Ask it here.
6" suspension lift with 3" body lift?
Old Jul 20, 2005 | 03:30 AM
third2121's Avatar
third2121 is an unknown quantity at this point
Default 6" suspension lift with 3" body lift?
i was wondering if with a 6" suspension lift if it would be unsafe and prone to roll over to add a 3 or 2" body lift?
Old Jul 25, 2005 | 02:23 PM
Hanr3's Avatar
Default RE: 6" suspension lift with 3" body lift?
No more prone then it is now. I find these trucks pretty stable off-road. The lift kit and body lift will raise your center of gravity and cause the truck to be more prone to rolling over, however to combat that you just need to slow down some. Not like your planning on doing high speed manuvers or anything are you? Plus you could gain back some of that stability by going with wider tires, and/or changing the backspacing on your wheels. Push them out further will give you a wider track and more stability. With that kind of lift you could run 33/12.5R15 tires on 15x8" wheels with a nuetral offset and be fine. Might have some clearance issues at full lock and/or full compression, however nothing a little pounding or trimming and fender flares won't fix.
Go for it, and post up pics.
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
von scott
Lifting Tech
Jul 1, 2009 10:46 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
