Suspension Tech Have a question about modifying your suspension? Ask it here.
96' Blazer
Old Nov 15, 2006 | 12:13 AM
one.shot.one.kill.'s Avatar
one.shot.one.kill. is an unknown quantity at this point
Default 96' Blazer
Hello,
I have just bought myself a 1996 Chevy Blazer 4x4. I am new to this forum and I need some help. I am a teenager working for minimum wage and I was wondering where I could find a reasonable priced and a reliable lift for my truck.
Thanks for your help.
Old Nov 15, 2006 | 05:10 PM
LunchBox's Avatar
LunchBox is an unknown quantity at this point
Default RE: 96' Blazer
ORIGINAL: one.shot.one.kill.
Hello,
First off, welcome...second, congrats on buying the sweetest ride known to man...the 96 Blazer 4x4 (2 doors are for men, 4 doors are for groceries).
Tell us: how big-a-lift are you looking at. If you just want to bump up a tire size or two:
The first thing you can do is crawl under the front doors with a wrench, and tighten your torsion bars. This gives you a bit higher stance, but will ride rougher, and wear your front end out faster, so that you have to drive the gas guzzling dually that gets 6 MPG, while someone hacks away at your Blazer, replacing $1000 worth of stuff that would have been ok, not to mention the $600 tires you ruined...so...yeah; torsion bars.
---and/or---
Body lifts will run you under $150, but you better put it on yourself with a buddy, because shop-time will cost you $500 or more. You can also trim your fenders and install fender flares...that may let you go up about another inch in tire size.
If your Blazer can run 30 x 9.5's stock, the torsion bars, body lift, and fender trimming might get you 32's...maaaaaaaaaaaybe 33's in there for under a grand.
Of course, the tires are expensive...
Old Nov 16, 2006 | 08:51 PM
First off thanks for welcoming me. I would like to do a 3" lift or so with some bigger wheels and tires. On the body lift. Where can you buy them and how much taller would it make it?
and..
We have a lift in out garage so I don't think it would be hard putting it on. I am used to Jeeps..things are a little different on Blazers.
also..
The Blazer is 4-door.
