Suspension Tech Have a question about modifying your suspension? Ask it here.
air bags on a 4x4 front end
Old Jan 4, 2008 | 09:16 PM
85v8blazer's Avatar
85v8blazer is an unknown quantity at this point
Default air bags on a 4x4 front end
I am looking into putting airbags on my 85 s10 blazer. I bought it from someone that changed the motor and the disconnected and ripped out all of the 4x4 gear so I am just left with the a-arms and such which gives me a little issue on clearance for airbags. I was wondering if anyone had any suggestions on the best way to do this. I have had someone tell me we could buy some tubular a arms and fab up a front end suspension setup to accept airbags. If yany of you have any other suggestions please share so I can try to figure this one out. Thanks
Old Jan 4, 2008 | 10:23 PM
thegr81's Avatar
Default RE: air bags on a 4x4 front end
Well what you can start off with is taking and swapping the spindles out with 2wd spindles then you can fab a lower bag mount on the lower a-arm and get tubular uppers for clearence. With the upper bag mount you can weld that to the side of the frame with gussetts and then plumb your air ride and there you go. There is a little more work involved you just have to have someone that knows all about building minitrucks there with you to help. I could go on and on cause i have been building mini's for years now but see if you can find someone near you first. Any other questions pm me and I will gladly answer them!
blazer_project
Mar 9, 2009 09:02 AM
hicklinc
Lowering Tech
May 14, 2008 10:55 PM
85v8blazer
Jan 4, 2008 09:29 PM
Blindthieves
Suspension Tech
Mar 6, 2007 12:41 AM
la~man
Suspension Tech
Jun 2, 2006 05:51 PM
