Suspension Tech Have a question about modifying your suspension? Ask it here.
alignment
Old Sep 14, 2006 | 01:38 AM
Njudkins21's Avatar
Njudkins21 is an unknown quantity at this point
Default alignment
hey this is probably the wrong spot for this but i have a 96 4 door blazer lt. when the truck is going straight, the wheel is turned to the left... pretty far!!! alignment issue? or something else? my buddies 95 is the opposite, the wheel is to to the... is it common? how can i fix it?
Old Sep 14, 2006 | 06:07 AM
lunatic_magnet's Avatar
lunatic_magnet is an unknown quantity at this point
Default RE: alignment
take it to a shop and get an alignment... they should be able to make it go straight or tell you if something is bent and causing a problem.
Old Dec 6, 2006 | 05:40 PM
emgoodyear's Avatar
emgoodyear is an unknown quantity at this point
Not sure about the 96's but on my 88 all that needs adjusting is the Steering Dampener. They are two tie rod (looking) ends with a sleeve that needs to be adjusted.
blazen_red_4x4
Oct 13, 2014 12:39 PM
88s10Blazer
Oct 16, 2006 12:11 PM
Walleye
Suspension Tech
Feb 26, 2006 10:35 PM
ivannj
Jan 31, 2006 11:30 PM
dblazer
Aug 24, 2005 08:16 PM
