Suspension Tech Have a question about modifying your suspension? Ask it here.
raise the rear
Old Dec 6, 2006 | 09:09 PM
FImports's Avatar
FImports is an unknown quantity at this point
Default raise the rear
looking to lift the back 2' advice anyone..thanks 92 s-10 blazer 4.3
Old Dec 6, 2006 | 09:24 PM
jimmyboy's Avatar
jimmyboy is an unknown quantity at this point
Default RE: raise the rear
you could get some shackles or you can get add-a-leaf from trailmaster, procomp, or fabtech
Old Dec 6, 2006 | 09:30 PM
jimmyboy's Avatar
here are some good looking shackles http://www.synergyoffroad.com/shackles.html
jimmyboy
Old Dec 6, 2006 | 09:31 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
You could put air shocks on the back. You would then be able to handle more tounge wieght and it would also lift your truck a bit.
Old Dec 6, 2006 | 10:02 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
just remeber with shackles, that you only get half the lift of the overall height of the shackles..... example, 2 inch taller shackles actually only give you 1 inch of lift...
Old Dec 7, 2006 | 01:22 AM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
those synergy shackles are built tough. I was a member on zr2.com before it closed down, and people were raving those shackles chris was building, good quality
e602
91
Mar 8, 2015 04:53 PM
wlorton
16
May 10, 2011 08:48 PM
96jimmyslt4x4
Suspension Tech
Apr 18, 2011 10:40 PM
vze4yrte
Mar 21, 2010 08:00 PM
RWRIGHT
Feb 26, 2009 07:56 PM
