Suspension Tech Have a question about modifying your suspension? Ask it here.
Best way to drop an '02 2 door blazer?
Old Feb 27, 2007 | 03:11 AM
JLaw's Avatar
JLaw is an unknown quantity at this point
Default Best way to drop an '02 2 door blazer?
[align=left]I recently bought a 2002 2 door Blazer (good price too, 8750 out the door with 54,000 miles). I was wondering what was the best way to get a 2"-3" drop on it. I was thinking 2" drop spindles in front and 3" drop blocks in rear. Is this a good method? Would this be all I need? And if so, how does the ride feel compared to stock? Any comments appreciated.
[/align]
Old Feb 27, 2007 | 05:27 AM
drperry's Avatar
Default RE: Best way to drop an '02 2 door blazer?
I think as long as the shocks are good for the length of travel, your ride will change minimally... A little rougher, but that's about it...
And please don't use the smallest font setting... Those of us with high resolutions on medium sized screens are gonna go blind, lol
Old Feb 27, 2007 | 06:26 AM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
The spindles would be good for a 2" drop on the front. They won't change your ride quality on the front because you're not touching the springs or shocks. I would stay away from the blocks though. 3" is kind of tall. It'll put way too much stress on your springs causing excessive axle wrap and spring failure. I'd reccomend springs for the back. A little more pricey, but definatly worth it.
Old Feb 28, 2007 | 09:59 PM
JLaw's Avatar
Would you know the best place to buy rear springs? I couldn't find any for my blazer at stylin concepts, DJM, or Beltech. And thanks for the advice on not using lowering blocks.
Old Feb 28, 2007 | 10:48 PM
speeddemon560's Avatar
speeddemon560 is an unknown quantity at this point
ORIGINAL: zero psi
Is it okay to use blocks on a 4wd Blazer? I don't have springs on mine, so I think I need blocks. Okay or not?
Old Feb 28, 2007 | 11:54 PM
LORCLAS's Avatar
LORCLAS is an unknown quantity at this point
I had 3" drop blocks back when I had my static drop and had no problems at all.
Old Mar 2, 2007 | 01:02 AM
BOTTOMFEEDER MINIS's Avatar
BOTTOMFEEDER MINIS is an unknown quantity at this point
drop spindles for the front and buy the EXTREME REAR SPRING DIRECTLY FROM CHEVY they are a little pricy at 400 EACH BUT U WILL HAVE THE SAME RIDE AS A EXTREME THEN JUST ADD SOME BELTECH SHOCKS ON ALL 4 CONERS AND U WILL BE SET
Old Mar 2, 2007 | 07:21 AM
drperry's Avatar
You can probably get equivalent replacement springs from a local parts shop, for a whole lot cheaper...
killallblue
Nov 18, 2011 06:38 PM
bigmatt1
Lifting Tech
16
Dec 31, 2009 05:07 AM
igot10pinitis
Lowering Tech
Sep 23, 2007 07:57 PM
JLaw
Suspension Tech
Mar 26, 2007 05:09 PM
ridin_low07
Jun 26, 2006 03:55 AM
