Suspension Tech Have a question about modifying your suspension? Ask it here.
built ford tough with chevy stuff
Old Jul 3, 2009 | 11:41 PM
dave selfridge's Avatar
dave selfridge is on a distinguished road
Angry built ford tough with chevy stuff
hi people:i just put 1975 blazer 4x4 suspension in my 63 ford pu.I used the ford frame but everthing from the steering column down is blazer.The steering does not work right,i can not get the wheels to come back to center on there own.Some help would be nice
Old Jul 4, 2009 | 09:20 AM
Sounds like the adjustment on the steering gear box is too tight. Were the parts new or used?
Old Jul 4, 2009 | 03:48 PM
bandidolenny's Avatar
Make sure the castor angle is correct. If the front axle was installed with shims or if it is installed in a way that causes the pinion to angle up at all from stock, then the castor angle will not be enough to center the tires after a turn.
Benedict1337
Jun 8, 2010 01:56 PM
blazinloud
Mar 29, 2008 01:24 PM
MADDOG`
Jan 5, 2008 03:42 PM
cwiththehad
Nov 26, 2007 05:21 PM
