Suspension Tech Have a question about modifying your suspension? Ask it here.
drop
Old Jan 28, 2006 | 03:44 AM
blazerxtreme1's Avatar
blazerxtreme1 is an unknown quantity at this point
Default drop
on a xtreme is there a one inch drop coil? or is it something else and is it true that if you use a 3 inch drop coil you only get 2 inches out of it?
Old Jan 28, 2006 | 03:51 AM
4lowlife's Avatar
Default RE: drop
I believe you have whats called a Z87 suspension, Not sure if its a revised ZQ8.
I think GM uses softer springs on it. Cheaper than lowered spindles.
Old Jan 30, 2006 | 10:19 PM
LORCLAS's Avatar
LORCLAS is an unknown quantity at this point
Default RE: drop
Xtremes have the ZQ8 suspension. Front springs are like an 1 1/2 shorter. I have not seen a 1-inch drop coil. Try Belltech.
Depends on how much of a drop you want.
Here are some pictures of mine when I had a static drop
http://www.cardomain.com/ride/579322/2
It has 2-inch drop spindles, 3-inch shorter coils and shorter shocks up front, and 3-inch drop blocks in back with shorter shocks.
Old Jan 30, 2006 | 10:31 PM
4lowlife's Avatar
Default RE: drop
Nice looking Blazer. You should enter the ride of the month.
Old Jan 31, 2006 | 03:19 PM
LORCLAS's Avatar
Default RE: drop
Thanks. I thought you had to be nominated for that? Can you nominate yourself? Not that I would, just asking.
I'll probably wait until Spring anyway. Have my Trailblazer font end by then. I hope.
Old Jan 31, 2006 | 07:18 PM
blazin97's Avatar
blazin97 is on a distinguished road
Default RE: drop
yes you have to be nominated an no you cant nominate yourself.
yearofthemonkey
Jul 20, 2005 11:53 PM
02 Vortech
Suspension Tech
Jun 23, 2005 03:23 PM
zero psi
Suspension Tech
13
May 24, 2005 05:17 PM
blazin97
Suspension Tech
Dec 13, 2004 12:06 AM
timetoblaze
Sep 28, 2004 08:16 PM
