Suspension Tech Have a question about modifying your suspension? Ask it here.
Drop ?'s
Old Sep 27, 2006 | 10:13 PM
rabbit0102030's Avatar
rabbit0102030 is an unknown quantity at this point
Default Drop ?'s
I'm lowering my 2001 blazer 2 dr. 3/3 with a Ground Force kit. I have 20's on it that rub a little when you turn the wheel all the way. When I lower it is it going to rub more or less, and how can I correct it?
Old Sep 28, 2006 | 12:02 AM
LORCLAS's Avatar
LORCLAS is an unknown quantity at this point
Default RE: Drop ?'s
Don't turn all the way. Ha.
How wide are the 20's? What is your overall diameter? Bigger then stock?
If you rub now you will probably rub more when lowered.
Old Sep 28, 2006 | 12:10 AM
9.5 wide or maybe 10 dont really remember and diameter I believe is 21.5 maybe a little more.
Old Sep 28, 2006 | 01:11 AM
jagblazer01's Avatar
how far will that tuck the tire up in the wheel wells? and what are u rubbing on? the frame?
Old Sep 28, 2006 | 01:23 AM
The tire rubs the frame. I should have 6 inches from top of the tire to top of the wheel well in the rear and 5 in the front. What do you think? I'm not worried about bottoming out, it will not be low enough for that. I'm worried that it will rub even more on the frame and maybe the inner part of the fender.
Old Sep 28, 2006 | 09:20 AM
LORCLAS's Avatar
ORIGINAL: rabbit0102030
Damn. I have 18 x 8's and I rubbed a little when I had my static drop. Mine was wheel well. I don't think I was hitting frame. Only solution was not to turn as hard.
Old Sep 28, 2006 | 10:23 AM
yea all i can think of is you wont be able to turn as hard
Old Oct 3, 2006 | 03:32 AM
djremix's Avatar
djremix is an unknown quantity at this point
I have 17X9 on a 5/5 drop and I don't rub...I still don't take any chances by turning hard either, I try to be careful with my daily driver. I am thinking Yes you will rub more with 20" and a slight drop.
Old Oct 6, 2006 | 03:22 PM
offroaddude77's Avatar
offroaddude77 is an unknown quantity at this point
i want to add something on a side note for concideration. when i lowered my blazer i started off with a 4-4 drop and it was lowering the rear. so i had to make it 5-4. it now has a little rake in the front by just a 1/2" or so. i think an even 3/3 drop might make it look lower in the rear. a couple other people with 2dr 2wd blazers have found this out also the hard way when lowering theirs.
Old Nov 12, 2006 | 02:35 AM
00blackblazer's Avatar
00blackblazer is an unknown quantity at this point
iknow this is an old thread but rabbit your from my area hit me up and ill help ya pick out the right drop for you. ive seen you cruising around the schertz area. mines a 2000 blazer dropped 5/5 all belltech on 20's
yearofthemonkey
Jul 20, 2005 11:53 PM
02 Vortech
Suspension Tech
Jun 23, 2005 03:23 PM
zero psi
Suspension Tech
13
May 24, 2005 05:17 PM
blazin97
Suspension Tech
Dec 13, 2004 12:06 AM
timetoblaze
Sep 28, 2004 08:16 PM
