Suspension Tech Have a question about modifying your suspension? Ask it here.
front suspension and steering alignment
Old Jan 3, 2007 | 04:23 PM
Marcin's Avatar
Marcin is an unknown quantity at this point
Default front suspension and steering alignment
Hi
I think I should check in my Blazer front suspension geometry after changing some parts but I can not find any data for proper alignment for example toe-in. Could you tell me what shoul I check and what is proper data to set it up?
Thanks in advance, Marcin
Old Jan 25, 2007 | 05:48 PM
thegr81's Avatar
Default RE: front suspension and steering alignment
i would deffinitly get it on a alignment rack before u spend more money on tires than u should have to if your toe is off u could cause what its called a dragging tire and it doesn't take long at all before that blows out and if it is a repeated process it wears out your suspension componets quick on a 4wd your front needs to be straight up and down and toed in just a lil bit cause with the front toed in a lil bit the force of going forward pushes the toe out to were it needs to be when driving but i would take it to an alignment shop that specializes or is real familiar with 4wd alignments.
Old Jan 25, 2007 | 06:08 PM
Marcin's Avatar
Hi
I bought data and now alignment was set up properly. The problem was that Blazer was rather rare car here in Poland and mechanics had no alignment data for it.
Marcin
blazen_red_4x4
Oct 13, 2014 12:39 PM
SOB1999JIMMY
Jun 2, 2012 10:33 PM
jaydon44
Jan 18, 2012 03:35 PM
lombard
Jan 26, 2011 01:49 PM
JTalley
Dec 3, 2010 09:57 AM
