Suspension Tech Have a question about modifying your suspension? Ask it here.
hoe makes a good 2 inch lift
Old Oct 26, 2006 | 02:23 AM
mikehillis1@yahoo.co's Avatar
mikehillis1@yahoo.co is an unknown quantity at this point
Default hoe makes a good 2 inch lift
for a 1995 4x4 blazer??
Old Oct 28, 2006 | 06:28 PM
Cow Killer's Avatar
Cow Killer is an unknown quantity at this point
Default RE: hoe makes a good 2 inch lift
what kind, suspension or body?
Old Nov 7, 2006 | 09:11 PM
BlackBlaze's Avatar
BlackBlaze is an unknown quantity at this point
How much will it set you back?
Old Nov 7, 2006 | 11:06 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Superlifts makes a good 2" suspension lift for Gen2 s10 blazers and performance accessories makes a good 2" body lift for gen2 s10 blazers.... not worth it to me... you can fit 30" tires on a stock height blazer... the largest you can go with a 2" is 31" tires.... not worth the money for technically only 1/2" of lift. . . . invest your money in some good 30x9.50's and you can go anywhere the 31" guys can go. . .
Old Nov 8, 2006 | 08:52 PM
cody32401's Avatar
cody32401 is an unknown quantity at this point
you can get a 2in body lift for like 90 bucks you just gotta look or you can make it yourself with
2 inch square tubing if you wanna cut some corners
but a-tack is right not really worht it
Old Nov 9, 2006 | 02:39 PM
thanks what about turning my torshin bars
Old Nov 9, 2006 | 02:47 PM
a_tack's Avatar
It's a cheap fix... I'm cosidering doing it myself. . however, it can put added stress on your front end and 4wd components. I'm only going 3/4"-1" to make the truck look more level. . any more than that can put your CV shafts at a dangerous angle. . get them in a bind in 4wd and you could snap one... not fun. . .
Old Nov 10, 2006 | 01:34 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
ORIGINAL: a_tack
I don't know about that one... I put a 3" body lift on and 31's and my buddie gets stuck with his 94 Blazer way more than I do. I always have to bring a tow rope for him, we go up on the logging roads. He has no lift and 30" BFG M/T. I like my 31's with the 3" lift. It makes it look more aggressive...
But as to you Mike Hillis, I would get a 3" Body Lift for 100 bux and do that.
Old Nov 10, 2006 | 08:24 PM
ceanern's Avatar
ceanern is an unknown quantity at this point
don't think they make 3" for are year blazers or atleast I havn't say I have seen any yet.
BlazinHo
May 11, 2014 06:09 PM
Sisk
Feb 2, 2011 07:22 AM
Keeler
Lifting Tech
22
May 29, 2010 03:53 AM
