Suspension Tech Have a question about modifying your suspension? Ask it here.
how much higher does..
Old Jan 13, 2007 | 04:32 PM
mudsliner's Avatar
mudsliner is an unknown quantity at this point
Default how much higher does..
how much higherdoes a ZR2 sit then jus u reguler 2dr 4x4?
Old Jan 13, 2007 | 10:10 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: how much higher does..
roughly 2 inches..
Old Jan 14, 2007 | 01:50 AM
mudsliner's Avatar
alright i want to make mine sit at bout the same as the ZR2s so if i get a 2 inch lift i should b around the same hieght
Old Jan 14, 2007 | 03:05 AM
a_tack's Avatar
yea... but I wouldnt put a 2 inch on it.... all the 2 inch lift kits do is crank your t-bars and replace the upper control arms.... its hell on the front end.... they also come with warnings that read "not for hard off-road use".... if ur just wanting it for looks it would be good, but if its for play...... not a good idea....
Old Jan 14, 2007 | 06:15 PM
mudsliner's Avatar
o it goin to be for play. i was really want a 3-4 inch lift but cant seem to find one anywhere that i can afford.
Old Jan 14, 2007 | 06:29 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
So if I go with a 2 inch suspension lift you think it will really lift me 2 inches. I just want it for looks but there will be times when I will do minor off roading, like this would be seldom. What are the risks I face if I do this?
Old Jan 14, 2007 | 08:22 PM
a_tack's Avatar
k..... mudsliner.... trailmaster makes a very good 5" lift for your truck.. .I would reccomend checking it out.......
bmx.... the 2 inch lifts kill your ball joints, and also puts your cv shafts a extremely dangerous angles. If you get them in a bind you could break them. It cranks your t-bars to the max and kills your ride quality.... if you go with something like a 5 inch it comes with drop brackets for everything. The 2 inch lift produced by any company isnt a great idea... I mean they are alright, but be careful.
Old Jan 14, 2007 | 09:10 PM
mudsliner's Avatar
yea ive looked at the trailmaster 5inch lift. cant afford it i was lookin for something small so i can get bigger tires and i dont want a body lift. the reason wanting a 3 inch lift.
Old Jan 14, 2007 | 09:50 PM
a_tack's Avatar
to be honest with you... a body lift is probably your best bet...
Old Jan 14, 2007 | 10:02 PM
mudsliner's Avatar
no i dont like body lifts. but i think i found what im lookin for but go to wait till tuesday to call my local offroad shop.
