Suspension Tech Have a question about modifying your suspension? Ask it here.
leaf over lift
Old Jan 1, 2011 | 07:27 PM
bdashwood87's Avatar
bdashwood87 is on a distinguished road
Default leaf over lift
i was wandering if anybody might have a little info for me. i wanna do a little t bar crank but i cant remember or find it on the site. how many bolt turns is an inch and how many inches is an ok amount. I would also like to do a leaf over lift for the rear. im ok with shackels but am under the impression that essentially all that would have to be done is unbolt leafs from frame and axle turn over u bolts and put leafs on top of axle n bolt back up?
Old Jan 2, 2011 | 10:27 PM
mdehoogh's Avatar
Springs can wear out so it's not like an exact measurement but it's generally accepted that one full turn of the adjusting bolt is approximately a quarter inch of lift. As far as how many is okay, that's a trickier question and one that can't really be answered. I would say not to crank more than you need to because with the tbars cranked, the CVaxles and balljoints are working at a steeper angle and will wear out faster.
I cranked up 7 full turns just to get my tires to fit but I'm lowering down some and I'm down to 4.5 turns right now. I didn't take any measurements so I can't say how much I gained from the initial crank or how much I lost from the subsequent lowering.
The spring over axle will get you more like 4-5" because of the thickness of the axle itself combined with the thickness of the leaf pack. The plate that the ubolts attach to also has the bracket for the shocks so you might need to modify that. I'm not sure if you can simply flip it to the top or not.
Old Jan 2, 2011 | 11:21 PM
ABN31B's Avatar
Old Jan 3, 2011 | 09:52 PM
thanks for the help finding those posts they wer quit helpful. maybe in the future i might start collecting the parts needed for a solid axle swap on my 96 blazer but for now i just wanted to get my frame a little higher cause we got about 4-5 feet of snow in south dakota. i was gunna do a cheap 2 inch body lift with 2 inch piece of pipe but havent gotten to it yet. well any advice is welcome..
Old Jan 3, 2011 | 10:03 PM
ABN31B's Avatar
if you are dealing with 4-5 feet of snow i suggest an older used snow cat
a body lift wont help you in clearing snow too much since your frame/axles/suspensiony parts will all be at the same height.
combine a 2" BL with a t-bar crank and lift shackles in the rear AND bigger tires should get you maybe an inch or two worth of gained clearance...tops.
for the cost of a SAS for your 96, you could just buy a beater truck for winter...
02Goldie_Loks
Sep 11, 2015 05:47 PM
hurleyii
Mar 18, 2014 07:23 AM
gitch93
Oct 24, 2012 12:07 PM
LucasMI
Jan 2, 2012 02:15 PM
musclemasterflex
Suspension Tech
Aug 26, 2011 09:10 AM
