Suspension Tech Have a question about modifying your suspension? Ask it here.
leaf springs above the axle
Old Feb 11, 2010 | 07:27 PM
jayjen1317's Avatar
jayjen1317 is on a distinguished road
Default leaf springs above the axle
can we move our axles under the leaf springs, looks like it would be fairly simple?
Has anybody done this? any reason why we shouldnt?
Old Feb 11, 2010 | 07:47 PM
Sure you can, it is called the SOA (spring over axle) swap. However, this will raise the back end ~4" and the closest front end lift is the 5" or 6" suspension lifts which drops the front diff down lower using brackets.
Old Feb 11, 2010 | 08:06 PM
NVANZEE's Avatar
it will lift it 5in but like kyle said to get the front to match you will have to buy a kit
Old Feb 11, 2010 | 08:28 PM
jayjen1317's Avatar
so getting the front to match is the problem, with doing that?
it would be easy for to do just the back but expensive to get the front to match
Old Feb 11, 2010 | 08:37 PM
NVANZEE's Avatar
correct
Old Feb 12, 2010 | 12:23 AM
ABN31B's Avatar
just go for a EXTREMELY raked look
rat fink style
Old Feb 12, 2010 | 01:44 AM
papacope's Avatar
Originally Posted by abn31b
just go for a extrely raked look :d
rat fink style
lmfao!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!
Old Feb 12, 2010 | 12:59 PM
abig84's Avatar
Easy as cutting off the spring perches and rewelding new ones up top. Did it on mine using the stock springs
Old Jul 30, 2010 | 09:23 AM
Crispy23's Avatar
Crispy23 is on a distinguished road
if you were to flip the brackets in the rear where do you get the lift kit for the front end ?
Old Jul 30, 2010 | 12:22 PM
abig84's Avatar
Yea basically. So whatever lift you get in the back just buy the one for the front the same height
