Suspension Tech Have a question about modifying your suspension? Ask it here.
Lift Blocks??
Old Apr 23, 2008 | 10:54 AM
BlazerBarnes08's Avatar
BlazerBarnes08 is an unknown quantity at this point
Default Lift Blocks??
I have a '96 Blazer 4d 4x4. I was wondering if it would be a good idea to put 3inch body lift in the front and back. has anyone out theredone this to their blazer? I would like to know if this is a good idea? thank you
Old Apr 23, 2008 | 11:02 AM
mdehoogh's Avatar
Default RE: Lift Blocks??
Several people out there have 2" body lifts for them. The only one I know of that has a 3"BL on a second gen (95-05) is Taymacjack. There are several first gens with a 3"BL.
Old Apr 23, 2008 | 11:07 AM
jimmyboy's Avatar
jimmyboy is an unknown quantity at this point
just a clearification lift blocks and body lift are not one in the same. body liftjust lifts the body and blocks are put on the axle to lift the suspension that way. but on the s-series truck you can not use lift blocks to lift the truck it actually lowers it.
jimmyboy
Old Apr 23, 2008 | 11:13 AM
lennyblazer's Avatar
lennyblazer is on a distinguished road
I have only heard of the 2" body lifts for the second gen trucks, a 3" lift would be custom done. The only way a suspension block system would work is if you did a spring over axle conversion in the rear (SOA), which gets you 5-6" of lift I believe just doing the SOA. Otherwise like jimmyboy said, it will lower the blazer.
mov4x4
Lifting Tech
Oct 31, 2010 11:44 PM
t3clay
Feb 9, 2009 11:54 AM
hannibaldeschain
Aug 23, 2007 11:49 PM
agent305
Lowering Tech
Apr 23, 2007 06:46 PM
bhrconcepts
Suspension Tech
Jan 15, 2007 04:47 PM
