Suspension Tech Have a question about modifying your suspension? Ask it here.
lift kit ordered!!!
Old Nov 3, 2007 | 10:08 PM
*TLR*'s Avatar
*TLR* is an unknown quantity at this point
Default lift kit ordered!!!
do you think it will look decent?
how much higher do you all think my blazer will sit after all installed?
yep finally did it ordered
4 long shocks for lifts
2' suspension lift
2" body lift
4 33/12.50R15 pro comp tires
cannot wait, i have one more week befre i am home from iraq. now i have a project to look forward too. my son is just over one....i have to get his help handing me tools early. cannot wait to be back with my family. i have a 2002 blazer 4x4 4dr black with charcoal interior. After i lift it i will purchase the side tubes in black to hide some of the frame exposed by the body lift.
Item:
279962 PRO COMP RADIAL X-TERRAIN
Quantity:
4 @ Total Price:$607.96 USD
Status:
Pending - Click here for current status!
Item:
940891 ROUGH COUNTRY LIFT KIT 2" CHEV/GMC
Quantity:
1 @ Total Price:$375.99 USD
Status:
Item:
076643 BODY LIFT KIT 2" CHEV/GMC
Quantity:
1 @ Total Price:$167.19 USD
Status:
Item:
730001 SHOCK BOOT RED
Quantity:
2 @ Total Price:$6.38 USD
Status:
Item:
383689 NITRO 9000 SHOCK ABSORBER
Quantity:
2 @ Total Price:$55.98 USD
Status:
Item:
Quantity:
Status:
Item:
381749 NITRO 9000 SHOCK ABSORBER
Quantity:
Status:
Old Nov 3, 2007 | 10:13 PM
Blazin_Jason's Avatar
Default RE: lift kit ordered!!!
Sounds good, should look sexy! Gonna get some "comments" on the 2" Suspension lift. I wouldn't have bought it though. What series are the tires?
Old Nov 3, 2007 | 10:14 PM
*TLR*'s Avatar
hold one ill check the series of tires
here you go
http://www.jcwhitney.com/autoparts/S...;sku=zx279962f
pro comp X-TERRAIN® TIRE
Old Nov 3, 2007 | 10:25 PM
*TLR*'s Avatar
i fgured i would do both the 2" body and 2" suspension....i really wanted the 33" tires....if i tweaked the suspension 2 inches and only did the 2"body i was affraid the 33"'s might rub on front...wanted to make sure clearance was definately not an issue....and i dont think i am really ready to jump to the 6" suspension lift because it requires welding and them id have to spend even more for some 35" tires....which then i would have to go to an after market wheel too.....at least i can stay with the factory rims since i bought the 33/12.5R15's
Old Nov 3, 2007 | 10:30 PM
Xterrains are sweet. A buddy has some on his truck, nice aggressive look. They are on sale now buy 3 get 1 free. That usually happens every fall. The thing with the 2" susp lift, is that it can be done for cheaper. Crank the torsion bars and lift the back with shackles or something. You might have rubbing at full lock due to the width of the tires. I will be running 33,10.50's with a slight torsion bar crank and 1.5" spacers. Even then it's close to rubbing. All trucks are different though, just something to watch for.
Old Nov 3, 2007 | 10:35 PM
*TLR*'s Avatar
if it rubs would spacer that bring the tires slightly wider help, or make it worse?
EDITED: to add question?
but by doing the 2" suspension lift which come with new torsion bars, cant i even tighting the torsion bars even more to squeeze off another 1-1.5 inches....to make like 3-3.5" lift.... the sails man for rough country said they say 2" but really can squeeze off more, they just say 2" cause they try to help you save on wear and tear by keeping it closer to the 2 "
or did he feed me bullshize
Old Nov 3, 2007 | 10:38 PM
The spacers would act as if though the wheel had more backspacing, so it should help. Then you need to make sure that it clears the back of the front fender. Rcars on here has 33's on his truck with a similar setup. My truck is a first gen though and has bushwacker cutouts, so the fenders are "trimmed".
Old Nov 3, 2007 | 10:43 PM
*TLR*'s Avatar
i guessi could use my neumatic grinding disc and cut away the inner of the front fenders and use old rubber mud flaps from semi-trucks to make a newer inner-fender with more room if needed
Jkrumm
Lifting Tech
Feb 17, 2011 04:35 PM
ericthughes
Lifting Tech
Oct 13, 2010 10:56 PM
Blazin_Jason
Engine & Internal
17
Apr 11, 2007 09:38 PM
2Tone
Mar 23, 2007 10:13 PM
Kenton
Headers, Intake, & Exhaust
14
Nov 27, 2006 06:35 PM
