Suspension Tech Have a question about modifying your suspension? Ask it here.
liftin my 2000 blazer
Old Feb 2, 2009 | 11:33 PM
NVANZEE's Avatar
Default RE: liftin my 2000 blazer
well the problem with the RC lift is that all your doing is cranking the tbars. You dont want to go past 1.5" or your angles are too extreme and you will go through of balljoints a lot faster. So therefore your not getting a full 2". It also depends if you are going to be doing any trail riding or is it just for looks. My 31's have hardly any tread left (4/32) and i still caught the top of the fenders a few times while on the trails. I have a 1" tbar crank.
Old Feb 2, 2009 | 11:38 PM
bandidolenny's Avatar
I am workin on gettin my digital camera fixed so no I dont right now. This forum is full of blazer owners that have 2" lifts and 31s. If you search around I am sure you can find some pics to see what it looks like. I drove around for a year on BFG ATs on stock wheels with a 2" lift and never had a problem. I only recently added a body lift because I want to go to 33s.
Yes, if you plan on doing some serious off roading then you will rub the tires. If so then go with the 5" suspension kit. I amconsidering that myself.
Old Feb 2, 2009 | 11:52 PM
NVANZEE's Avatar
Look in my gallery for pics. i have a 1" tbar crank and 2" add a leafs. Your front end will sit 1/2" higher.
ORIGINAL: bandidolenny
That is possible if you stay on the roads. if you go on the trails you will rub guaranteed. I have hit the top of my fenders twice witch makes a nice cut in my treads and bends the fender up a little. I have pics to prove it. Also with out a LOT of trimming you wont be able to fit 33's.
Old Feb 3, 2009 | 12:01 AM
I am fixing to borrow some 33s to experiment with. I have a sawzall and a credit card and am not afraid to use them...[8D]
Old Feb 3, 2009 | 12:08 AM
NVANZEE's Avatar
If you have the money then order a 6" superlift. your gona need it. the kit even recommend 33s.
I have also have a 2"body lift along with the 1.5" tbar crank with 31s and if you want a pic i will show you how close i am to the fender along with the damage to the fender.
Just because you added a 2" body lift doesnt mean you can add 2" bigger tires.
Old Feb 3, 2009 | 08:43 AM
spankyy's Avatar
spankyy is an unknown quantity at this point
i think im just got to get a set of these GRABBER AT2[/b] 30x9.50 R15 they will fit on my stock rims with no rub right lol the web site sayed the are the same a 235/75R15 but i just want to make sure
Old Feb 3, 2009 | 10:22 AM
papacope's Avatar
235/75R15 is a 29X9.25. it's what i run. i only rub because i have aftermarket wheels with wicked backspacing.
Old Feb 3, 2009 | 09:09 PM
NVANZEE's Avatar
ORIGINAL: spankyy
i think im just got to get a set of these GRABBER AT2 30x9.50 R15
those will be perfect. you might have to crank the tbars a little depending on how much they are sagging.
Old Feb 12, 2009 | 06:52 AM
bammontana's Avatar
bammontana has a little shameless behavior in the past
I have the T-Bar cranked 1.5 inch, 2 inch body lift and that sits on 31 x 10.50 with a 4.5 backspacing and 1 inch adapter. Yea, they rub.
jello219
Sep 3, 2019 05:19 PM
01Blaze218
Oct 13, 2011 10:05 AM
DannyBanana
Lifting Tech
Sep 25, 2011 07:05 PM
spankyy
Lifting Tech
Oct 15, 2009 03:45 PM
cowboy717
Suspension Tech
Feb 27, 2007 10:42 PM
