Suspension Tech Have a question about modifying your suspension? Ask it here.
lifting my zr2
Old Oct 22, 2012 | 05:51 PM
Zr2Newbie's Avatar
From: From Grand Blanc MI currently in Big Rapids MI
Zr2Newbie is on a distinguished road
Default lifting my zr2
I new to lifting vehicles so I don't know what all it entails. I'm looking at starting out small since I'm on a college budget. What are the differnce between shakle and adding a leaf and what would u recommend is the best bang for your buck?
Old Oct 22, 2012 | 06:58 PM
warthogdriver's Avatar
you can do a shackle and torsion bar lift for around 100.00 that will give you
2inches in the rear and 1.5 in the front. about as cheap as you can get.
add a leaf will do the same...but i think that most do the shackle lift.
check the lifting section...all you need to know will be there.
Old Oct 22, 2012 | 09:15 PM
Zr2Newbie's Avatar
I heard the torsion bar lift can ruin ur front suspension?
Old Oct 22, 2012 | 09:28 PM
Only if you go more then 1.5"above stock height.
I had that setup for years prior to my suspension lift...never had anything fail prematurely.
Old Oct 22, 2012 | 10:00 PM
Zr2Newbie's Avatar
I heard if u do u will need a alignment is that true for the shackles in the rear
Old Oct 23, 2012 | 06:46 AM
no...alignment issue only comes from messing with the front end. if you lift the rear i cant see how it would affect alignment in the front steering
Old Oct 23, 2012 | 07:41 AM
Zr2Newbie's Avatar
Ok so just on the tbar lift correct?
Old Oct 23, 2012 | 08:48 AM
yes...search for the torsion bar lift how to...will tell ya all you need to know.
Old Nov 8, 2012 | 08:42 PM
Zr2Newbie's Avatar
When getting shakles or add a leaf lifts do i have to get Zr2 specfic ones or not?
Old Nov 9, 2012 | 06:48 AM
Jamaroon's Avatar
no, just need to be for the correct spring width
