Suspension Tech Have a question about modifying your suspension? Ask it here.
limited slip time
Old Feb 12, 2007 | 11:20 PM
RedBlaze's Avatar
From: Atlantic, NC (eastside whats crack-a-lackin!)
RedBlaze is an unknown quantity at this point
Default limited slip time
Well im gettin sick of my blazers open differentials.. So when I get the money saved up I'm gonna put torsen style limited slip carriers in front and back along with some 3.73 gear. I considered lockers but I dont want the decreased driveability on the road. Is anybody running the torsen setup out there?? Also I am not real familiar with the IFS on these blazers. Is there anything special I need?? Or just the carrier, ring and pinion gear, and possibly some new bearings. (pretty sure ill get them changed while it is apart)
My blazer is a 2000 non-zr2 4x4 with automatic trans. right now it has open diffs and 3.42 gear
One more question. I believe that I have the 7.625" diff with 28 spline axels. Does this sound right?? Are there RPO codes for this so i can be sure?
Old Feb 13, 2007 | 06:25 AM
drperry's Avatar
Default RE: limited slip time
Yes, the Blazer has a 28 spline axle, however, I would NOT reccomend putting an LSD in the front diff... It's an aluminum housing, so I don't know if it can take the oomph it needs for LSD style work...
Old Feb 23, 2007 | 05:59 PM
thegr81's Avatar
if you plan on lifting your blaze and want lsd i would switch from independent to a straight axle
96Superflow
Dec 24, 2007 05:04 PM
anasasisxenophontis
Dec 13, 2007 01:11 AM
walkingtall
Jan 25, 2007 07:36 AM
walkingtall
Nov 27, 2006 11:07 PM
PhatKat
Mar 30, 2006 09:32 PM
