Suspension Tech Have a question about modifying your suspension? Ask it here.
New Bushings?
Old Aug 17, 2006 | 02:59 AM
OCblazerowner's Avatar
OCblazerowner is an unknown quantity at this point
Default New Bushings?
I have a 96 S10 Blazer when im driving it pulls to the right I've checked the allignment several times it always shows good. Im wondering if i replaced the bushings in my control arms would it help at all. Hope it does cause im going through tires left and right!
Thanks for the help!
Old Aug 17, 2006 | 11:06 AM
lunatic_magnet's Avatar
lunatic_magnet is an unknown quantity at this point
Default RE: New Bushings?
but the place that does your alignments should be telling you if they find worn parts that are causing problems. i dont know how they could give you an alignment and tell you youre good to go if the bushings were bad enough to cause a problem... where are the tires wearing?
Old Aug 17, 2006 | 03:56 PM
I do all my own work. Thats why i was wondering.
Old Aug 26, 2006 | 02:03 PM
how are you doing the alignment yourself? you can check the toe with a tape measure and whatnot but to really get an alignment (caster/camber/etc etc) you have to put on a good machine.
improper caster or camber can definately be causing problems. sloppy bushings could be part of it, but something could be bent too.
if you havent had a pro alignment done i'd say that would be the first step and go from there.
cage47
Jun 11, 2010 12:17 PM
BlazerGuy2001
Suspension Tech
15
May 3, 2010 10:09 PM
cherryred4x4
Suspension Tech
Dec 14, 2006 09:27 PM
Major Pain
Suspension Tech
Dec 17, 2005 08:37 PM
joshsamson01
Mar 8, 2005 08:54 PM
