Suspension Tech Have a question about modifying your suspension? Ask it here.
ProComp ES3000's
Old Nov 4, 2009 | 01:31 AM
BlaziNator's Avatar
BlaziNator is on a distinguished road
Default ProComp ES3000's
So I bought two sets of Pro Comp ES3000 shocks for my blazer and my wife's. Reason being, the stock ones were limiting rear articulation with my lift shackles. I installed them in the rear and afterwards I found that the rear was riding 1/4 lower than before. I'm assuming this is due to the ProComps not being sprung like the stock ones. This isn't a problem in the rear, but up front, my keys are already cranked all the way so I could get a solid 1 1/2 inches of lift. Apparently my T-bars are really worn out. I need every little bit I can get to clear my 31x10.5's. So, should I go ahead and put them on up front too? Or should I replace them with some high quality sprung ones? Is it possible that I had to crank the T-bars as much as I did because the front shocks are shot? When I replaced my ball joints, I disconnected my passenger shock so I could play with my CV axle. I do not remember it being half as stiff as the rear ones I took off. Any input would be great.
Old Nov 27, 2009 | 07:05 PM
Brianator99's Avatar
Brianator99 is an unknown quantity at this point
So your going to have a lower stance up front and your probably going to rub because of it. Sounds like start trimming or buy some other shocks. My ranchos I think lowered mine also like you are saying. Do you think these new shocks gave you that much more articulation?
Old Nov 29, 2009 | 02:47 AM
BlaziNator's Avatar
Yeah, I've decided to keep OE shocks up front. The ProComp's travel an extra inch and a half or so. Translates to just enough articulation for me =)
Old Nov 29, 2009 | 11:39 AM
RebelJimmy96's Avatar
RebelJimmy96 is on a distinguished road
i have found that bilstines or rancho rs-5000's are the best for that setup!
musclemasterflex
Sep 6, 2011 03:24 PM
OILCOUNTRY
Lifting Tech
14
Mar 29, 2010 11:00 AM
Boopappa
Tires and Wheels
Jan 15, 2010 09:48 AM
king22
Tires and Wheels
Aug 16, 2009 08:37 PM
