Suspension Tech Have a question about modifying your suspension? Ask it here.
rough country
Old Dec 8, 2007 | 08:33 PM
Asimm's Avatar
Asimm is an unknown quantity at this point
Default rough country
I am buying a 1993 chevy s10 blazer lt tahoe 4dr with the 4wd button.
It has a rough country suspension installed.
Does any one know how good it is?
If not how can i tell?
Old Dec 8, 2007 | 09:09 PM
mdehoogh's Avatar
Default RE: rough country
how long has the lift been on? the ROUGH COUNTRY 2" LIFTadjusts the torsion barswhich increase the CV shaft angle. Over time, adjusted t-bars will cause increased wear on the CV shafts, and the ball joints can wear out much quicker than normal... you might want to check the condition the whole front end suspension and make sure everything works properly and smoothly. you might also want to ask if the ball joints have ever been replaced and ask if the previous owner was a heavy off-roader
Old Dec 9, 2007 | 09:06 AM
Asimm's Avatar
The previous owner was a teenager when he had it, he bought it off the lot brand new.
I belive that he had it put on in the 1990's but i am not shure. I will look at the paper work later.
It was a 1 personed owned vehicle.
motoraser125
Lifting Tech
Aug 19, 2008 11:07 PM
motoraser125
Lifting Tech
25
Feb 25, 2008 09:39 AM
lennyblazer
24
Jul 17, 2007 10:55 AM
mudsliner
Lifting Tech
May 12, 2007 06:17 PM
jagblazer01
Suspension Tech
Apr 5, 2007 03:31 AM
