Suspension Tech Have a question about modifying your suspension? Ask it here.
saggy front end
Old Feb 25, 2007 | 02:05 AM
fergi014's Avatar
fergi014 is an unknown quantity at this point
Default saggy front end
Hello everyone. I got a 2001 4x4 blazer and the front end sit really low. My front tires are P235/ 70/15 and the back are LT235/75 / the problem is I want to put 30x9's on it but the front will rub with any larger tires than 235/70 . Can any one help me with the issue.
Old Feb 25, 2007 | 02:47 AM
speeddemon560's Avatar
speeddemon560 is an unknown quantity at this point
Default RE: saggy front end
Got any pictures so I know how bad the sag is?
Old Feb 25, 2007 | 02:57 AM
fergi014's Avatar
No pics yet but on the right side the fender has 2 sit about 1 inch above the top of the tire. But on the driver side it might sit maybe 2 inches the tire.
Old Feb 28, 2007 | 05:35 PM
thegr81's Avatar
sounds like worn out springs and shocks if you want to get your front up try replacing those first or use lift springs and shocks if you want to get higher for bigger tires
Old Mar 3, 2007 | 06:02 PM
fergi014's Avatar
Thank To guys I was able to fix the saggy front end . I just crank up my t-barsabout 2' . Now it sit level
Old Mar 3, 2007 | 06:03 PM
fergi014's Avatar
Thanks to you guys
Old Mar 3, 2007 | 07:49 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Yeah, the 4x4's don't have front springs, and shocks have nothing to do with ride hieght...lol You are going to want to get a SET of tires all the same size...running different sizes on a 4x4 will eventually tear up your t-case. Glad you got the torsion bar thing figured out...now it's time for a good proper allignment.
Old Mar 20, 2007 | 09:41 PM
Arthur's Avatar
Arthur is an unknown quantity at this point
Supposedly cranking your torsion bar too high will wear out your ball joints, tear up your cv boots, and put a lot more strain on you're cv joints... despite these warnings I cranked mine up anyways
Old Mar 20, 2007 | 09:43 PM
lastcoupe's Avatar
All true.
AGodlyCanuck
Sep 12, 2014 01:51 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
TouringMike
Sep 22, 2011 09:22 PM
swizznuker
Apr 30, 2010 08:12 AM
DreadPirate_Davey
Lifting Tech
Dec 21, 2009 06:13 PM
