Suspension Tech Have a question about modifying your suspension? Ask it here.
Shackles HELP!!
Old Jul 20, 2009 | 03:01 PM
nyzr21019's Avatar
nyzr21019 is on a distinguished road
Default Shackles HELP!!
I know this has probablly been asked a million times but please just help me out on this one my blazer ZR2's rear end sags and i heard rear lift shackles help level it with the front end? where can i get them? and any other suggestions about the sagging?
thanks i need your help!!
Old Jul 20, 2009 | 03:27 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
shackles will help the sagging so will an add a leaf, but i would recomend a new leaf pack to cure the sagging(will be expensive tho) you can find shackles at synergyoffraod.com, ebay.com, or your local parts store you can even google lift shackles and youll find plenty of results.
Old Jul 20, 2009 | 05:28 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
you can even use the forum search feature. Thats what I use when I think something might have been asked a million times already.
Old Jul 20, 2009 | 06:23 PM
Big Keith's Avatar
Big Keith is on a distinguished road
Do a search for "ADD a leaf ?" I just did one on my ZR2
Old Jul 21, 2009 | 11:15 AM
nyzr21019's Avatar
hows the ride with it? and hows it look now?
Old Jul 21, 2009 | 02:09 PM
Big Keith's Avatar
Rids about the same as stock & leveled it out nicely looks good got 1" on driver side & 1 1/4" on passenger side & no more rear end squat on take off. I had to cut off the front spring clamps so they would fit reusing them until I make new ones I had to use a torch to get the U bolts off I recommend you have a torch handy & take off the shocks first it's easier. If you need new U bolts I got a universal kit from auto zone that were 10" long cut them to fit & only $20.00 instead of $40.00 if you buy them separately. Good luck & nice ride
Cavalier z24
Aug 9, 2012 02:12 PM
Ryanmatt135
May 22, 2010 01:44 PM
dirtydave
Suspension Tech
Dec 18, 2009 04:21 PM
speterson1011
Lifting Tech
Oct 11, 2009 01:46 PM
rocktheguitarist
Lifting Tech
Sep 6, 2009 05:34 PM
