Suspension Lifts available for S-Blazers
Many questions are asked about what size lifts are available for the S-10 Blazer and how much they cost. Between previously looking for a lift and a little research, this is the list I have created.
non-ZR2 Blazers (4wd)
Size___Manufacturer____Year______Part #_____Shocks_______________Price Range (US$)____Lift (F,R)_______Max. Tire Size Rec. By Manufacturer
Suspension Lifts
2"_____Superlift________83-04_____K451______Superride_____________$620-870___________(2"F, 1"R)______30x9.50 (31x10.50 should fit)
2"_____Rough Country___83-04_____7554______Heckethorn 8000_______$575-600___________(2"F, 1"R)______31x10.50
5"_____Trailmaster______83-94___CT10SSV____SSV__________________$1450-1750_________(5"F, 4"R)______31x10.50 (32 should fit)
5"_____Trailmaster______95-00___CT15SSV____SSV__________________$1360-1750_________(5"F, 4"R)______31x10.50 (32 should fit)
5"_____BDS____________88-05___Package*____BDS Hydraulic_________$2050-2250_________(5"F, 4.5"R)_____31x10.50 (32 should fit)
6"_____Superlift________95-00**_K790, K790B__Superride, Bilstein______$1630-2600_________(6"F, 5"R)______33x12.50 on 8" wheel
(4-Door ONLY)**
9"_____Fabritech_______Unlisted___Unlisted_____Per sonal preference____$Varies heavily_______(9")___________35x12.50
(11.5" Coming Soon) http://www.setstr8.com
Body Lifts
2"_____Perf. Accessories__84-94______542_______N/A__________________$90-120____________(2" ALL)________30x9.50
2"_____Perf. Accessories__95-97______132_______N/A__________________$130-160___________(2" ALL)________30x9.50
2"_________BDS_________94-97______9226______N/A___________________$195______________(2" ALL)________30x9.50
2"_________BDS_________98-04______9228______N/A___________________$260______________(2" ALL)________30x9.50
3"_____Perf. Accessories__84-94______543_______N/A___________________$95-130___________(3" ALL)________31x10.50
Prices vary depending on accessories added to kit. 9" Fabritech is a solid axle swap, uses a Dana 30 front axle from a Jeep Cherokee or YJ Wrangler. (Package*= composed of several kit numbers)
Suspension Lifts
(4-Door ONLY)**
Body Lifts
I believe the superlift has a lift for the 2 dr. as well. but good info. I will double check the 2 places I was looking at. definately good info. As I will be using this real soon. I hope!
What exactly is the difference between 2 dr. and 4 dr. other than the obvious. Would a zr-2 lift kit work on a non-zr2? Kinda fustrating. Seems every vehicle I get they either don't make the stuff I want for it or you have to custom fab it. Which is cool cause you know you will be the only one with it but when you don't have the time it is a pita!
the ZR-2 kits are different part numbers than the non-ZR2, the mounting locations on the suspension are different between non-ZR2 and ZR2. I looked into swapping a stock ZR2 suspension onto my 4 door and thats how i found out theyre all different, would be a complete PITA, lots of welding and fabrication.
as far as not finding stuff for your truck, most of the general parts that work for the S-10 pickup pf the same year range will also work for your Blazer, except forpickup body-style specific parts of course What year is your Blazer by the way?
i have the list of kits for ZR2 Blazers also, going to post all those up when I have more time..... then I'll post up the 2wd suspension lifts for anyone interested.
My blazer is a 99 LS 2 dr. I've tried finding a complete bolt up cat back but most places don't carry them or can't get them in. Can get it in for a 4 dr. but not 2 dr.
yeah, i was hoping someone would put it at the top, im going to add all the 2wd lifts and ZR2 lifts this evening after work.
i think another member had problems finding an exhaust for a 2-door, i think gibson makes one for the ZR2, but i dont know if he tried fitting it on his non-ZR2.
ORIGINAL: ceanern
I've been browsing the stylin concepts. That is where I found the lifts at. havn't had a chance to check out jegs or summit yet. What exactly is the difference between the suspenion on a 4 dr. and the 2 dr. Would you be able to get a suspension for a 4 dr. to fit a 2dr.? The welding part would worry me a bit. I'm working on getting better at it. But most of the stuff I have welded is at work and that is aluminum tray's. Not sure if that is easier or harder to work with than steel. I'm not to afraid to tackle the 5 or 6" lifts at my garage. Might give it a try if I can get the funds and I have the spare vehicle on the road by then. If I can get
