Suspension Tech Have a question about modifying your suspension? Ask it here.
Suspension Lifts available for S-Blazers
Old Jun 23, 2006 | 10:21 PM
jagblazer01's Avatar
Default RE: Suspension Lifts available for S-Blazers
im not exactly sure the difference b/w the 2 & 4 door....possibly the mounting points. try pm'ing swart or jman. they could help u a little better
Old Jun 25, 2006 | 07:40 PM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
the 2" lifts will fit a 2-door or 4-door, if its the 6-inch superlift kit that youre wondering about, I would try calling them and seeing if it will fit, or if they have any reccomendations on making it fit. Seems to me that if the 2" fits both, than the 6" should fit both. The only difference I can think of would be rear suspension mounting points, the 6" does a SOA (spring over axle) which might change things too much to fit the 2-door.
Old Jun 26, 2006 | 06:01 PM
ceanern's Avatar
ceanern is an unknown quantity at this point
I'm wondering if I couldn't make up a plate to mount to the top of my axle for the leafs to be bolted on to.
Old Jun 28, 2006 | 11:03 PM
It would have to be a pretty thick gauge metal to be used there, but it could be done. The kits come with rear lift though, I'm not sure if you can buy the front buy itself. You will definitely need longer brake lines and longer shocks if you do it.
Old Jun 29, 2006 | 08:08 PM
ceanern's Avatar
I'm figuring 1/4 or thicker. I'm just trying to figure out how much that would give by having the leafs mounted on top.
Old Jun 29, 2006 | 10:59 PM
you would gain about 4.5-5", the diameter of the axle tubes
Old Jun 30, 2006 | 07:41 AM
ceanern's Avatar
I need to hurry up and get a welder. haha That is a pretty good jump. Seems like that is basically what the superlift and other kits would do.
Old Sep 3, 2006 | 01:53 AM
mdnky's Avatar
mdnky is an unknown quantity at this point
ORIGINAL: cherryred4x4
That's exactly why it won't work on a 2 door. Drive-line angles become an issue and Superlift doesn't want to take on the liability of that.
Old Sep 3, 2006 | 04:04 PM
tommyd's Avatar
tommyd is an unknown quantity at this point
Can you post me a link to the Fabritech kit? I beleive this is a solid axel swap kit but I can't find their website
Old Sep 8, 2006 | 08:08 PM
surferbarnes's Avatar
surferbarnes is an unknown quantity at this point
Also i know that the company from Colorado called Mile High suspensions also offer a 6" lift for the ZR2 to fit 33x12.50
UwharrieMan
Lifting Tech
May 27, 2009 02:05 PM
RedNeckWagon360
Apr 3, 2009 11:53 AM
scattym
Lifting Tech
21
Feb 22, 2009 10:01 AM
BLK85
Sep 20, 2007 04:08 PM
aris_unlimited
Lifting Tech
Aug 2, 2007 02:26 PM
