Suspension Tech Have a question about modifying your suspension? Ask it here.
Suspension Lifts available for S-Blazers
Old Jun 20, 2006 | 12:45 AM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
Default Suspension Lifts available for S-Blazers
Many questions are asked about what size lifts are available for the S-10 Blazer and how much they cost. Between previously looking for a lift and a little research, this is the list I have created.
non-ZR2 Blazers (4wd)
Size___Manufacturer____Year______Part #_____Shocks_______________Price Range (US$)____Lift (F,R)_______Max. Tire Size Rec. By Manufacturer
Suspension Lifts
2"_____Superlift________83-04_____K451______Superride_____________$620-870___________(2"F, 1"R)______30x9.50 (31x10.50 should fit)
2"_____Rough Country___83-04_____7554______Heckethorn 8000_______$575-600___________(2"F, 1"R)______31x10.50
5"_____Trailmaster______83-94___CT10SSV____SSV__________________$1450-1750_________(5"F, 4"R)______31x10.50 (32 should fit)
5"_____Trailmaster______95-00___CT15SSV____SSV__________________$1360-1750_________(5"F, 4"R)______31x10.50 (32 should fit)
5"_____BDS____________88-05___Package*____BDS Hydraulic_________$2050-2250_________(5"F, 4.5"R)_____31x10.50 (32 should fit)
6"_____Superlift________95-00**_K790, K790B__Superride, Bilstein______$1630-2600_________(6"F, 5"R)______33x12.50 on 8" wheel
(4-Door ONLY)**
9"_____Fabritech_______Unlisted___Unlisted_____Per sonal preference____$Varies heavily_______(9")___________35x12.50
(11.5" Coming Soon) http://www.setstr8.com
Body Lifts
2"_____Perf. Accessories__84-94______542_______N/A__________________$90-120____________(2" ALL)________30x9.50
2"_____Perf. Accessories__95-97______132_______N/A__________________$130-160___________(2" ALL)________30x9.50
2"_________BDS_________94-97______9226______N/A___________________$195______________(2" ALL)________30x9.50
2"_________BDS_________98-04______9228______N/A___________________$260______________(2" ALL)________30x9.50
3"_____Perf. Accessories__84-94______543_______N/A___________________$95-130___________(3" ALL)________31x10.50
Prices vary depending on accessories added to kit. 9" Fabritech is a solid axle swap, uses a Dana 30 front axle from a Jeep Cherokee or YJ Wrangler. (Package*= composed of several kit numbers)
Old Jun 20, 2006 | 12:52 PM
ceanern's Avatar
ceanern is an unknown quantity at this point
Default RE: Suspension Lifts available for S-Blazers
I believe the superlift has a lift for the 2 dr. as well. but good info. I will double check the 2 places I was looking at. definately good info. As I will be using this real soon. I hope!
Old Jun 20, 2006 | 06:33 PM
on the superlift website it lists the 6" for 95-00 4-Door models only
the 2" lift will fit 2 or 4 door models
Old Jun 20, 2006 | 07:50 PM
ceanern's Avatar
What exactly is the difference between 2 dr. and 4 dr. other than the obvious. Would a zr-2 lift kit work on a non-zr2? Kinda fustrating. Seems every vehicle I get they either don't make the stuff I want for it or you have to custom fab it. Which is cool cause you know you will be the only one with it but when you don't have the time it is a pita!
Old Jun 20, 2006 | 10:48 PM
the ZR-2 kits are different part numbers than the non-ZR2, the mounting locations on the suspension are different between non-ZR2 and ZR2. I looked into swapping a stock ZR2 suspension onto my 4 door and thats how i found out theyre all different, would be a complete PITA, lots of welding and fabrication.
as far as not finding stuff for your truck, most of the general parts that work for the S-10 pickup pf the same year range will also work for your Blazer, except forpickup body-style specific parts of course What year is your Blazer by the way?
i have the list of kits for ZR2 Blazers also, going to post all those up when I have more time..... then I'll post up the 2wd suspension lifts for anyone interested.
Old Jun 21, 2006 | 01:29 AM
jagblazer01's Avatar
nice research cherry......i think this should be stickyed and then updated as needed
Old Jun 21, 2006 | 08:22 AM
ceanern's Avatar
My blazer is a 99 LS 2 dr. I've tried finding a complete bolt up cat back but most places don't carry them or can't get them in. Can get it in for a 4 dr. but not 2 dr.
Old Jun 21, 2006 | 12:08 PM
yeah, i was hoping someone would put it at the top, im going to add all the 2wd lifts and ZR2 lifts this evening after work.
i think another member had problems finding an exhaust for a 2-door, i think gibson makes one for the ZR2, but i dont know if he tried fitting it on his non-ZR2.
Old Jun 21, 2006 | 03:21 PM
ORIGINAL: ceanern
have you tried stylin concepts, jegs, and summit racing? they can usually get that kinda stuff even though it may not be listed on the website or magazine. if not you may have to get it custom made
Old Jun 21, 2006 | 05:35 PM
ceanern's Avatar
I've been browsing the stylin concepts. That is where I found the lifts at. havn't had a chance to check out jegs or summit yet. What exactly is the difference between the suspenion on a 4 dr. and the 2 dr. Would you be able to get a suspension for a 4 dr. to fit a 2dr.? The welding part would worry me a bit. I'm working on getting better at it. But most of the stuff I have welded is at work and that is aluminum tray's. Not sure if that is easier or harder to work with than steel. I'm not to afraid to tackle the 5 or 6" lifts at my garage. Might give it a try if I can get the funds and I have the spare vehicle on the road by then. If I can get
