Suspension Tech Have a question about modifying your suspension? Ask it here.
suspension tends to jump
Old Oct 15, 2007 | 02:30 AM
guillermoariast's Avatar
guillermoariast is an unknown quantity at this point
Default suspension tends to jump
Hello, i have a 1980 I6 250 ci Blazer K5. I have a problem, the suspension tends to jump when i pass on a rough road. I am thinking on install two shock absorbers beside each wheel.
Is it a real solution?
Greetings
Old Oct 15, 2007 | 04:16 AM
thegr81's Avatar
Default RE: suspension tends to jump
what do you mean by jump do you mean Hop like its got wheel hop if that is the case i would change the shocks out with new ones also if your suspension just seems to be all over the place then i would look into inspecting your bushings ball joints inspect the whole suspension and steering linkage
Old Oct 15, 2007 | 07:17 AM
I would say shocks as well. One quick way to tell is to jump off the front bumper and see how long it takes for the front end to stop moving up and down.
As far as ball joints go, there aren't any in the conventional sense on a solid front axle truck.
mysons95
Oct 31, 2008 05:49 AM
navyblue_sk8er
Mar 19, 2008 05:03 PM
kiko
Feb 19, 2008 02:42 AM
guillermoariast
Oct 15, 2007 07:23 AM
Moonzie
18
Jan 11, 2007 06:33 AM
