Suspension Tech Have a question about modifying your suspension? Ask it here.
Swapping lift kits
Old May 5, 2015 | 11:16 PM
Jamaroon's Avatar
you're not going to get more flex with any ifs lift kit. custom long(er) travel or sas are the only ways to get more flex
Old May 26, 2015 | 10:13 PM
robsteez's Avatar
robsteez is on a distinguished road
Originally Posted by AJBert
Just an FYI, no amount of lift gives you better ground clearance. The size/height of your tires gives you the ground clearance. All the lift does is allow bigger tires and more suspension travel.
A body lift will also allow you to put bigger tires on and may allow more suspension travel. So depending on how high you want to go, how much work you want to do and how much money you want to spend will determine which way you should go.
so you are saying no amount of lift will lift my frame higher off the ground for more clearance?
Old May 26, 2015 | 11:06 PM
lazyboyjake's Avatar
lazyboyjake is on a distinguished road
It does, but ground clearance is generally from the lowest point of the car which is the axle, not the frame.
03blazertucker
Lifting Tech
Feb 10, 2010 07:24 PM
tcd1388
Mar 21, 2007 07:07 AM
jessesjimmy
Suspension Tech
Jan 27, 2007 01:17 AM
97blz4x4
Suspension Tech
Nov 14, 2006 01:21 PM
mikehillis1@yahoo.co
Suspension Tech
Sep 19, 2006 12:28 PM
