Suspension Tech Have a question about modifying your suspension? Ask it here.
t-bar crank? again
Old Mar 25, 2007 | 02:08 AM
CrazyJ's Avatar
CrazyJ is an unknown quantity at this point
Default t-bar crank? again
Is it necessary to jack up the front end to release tension when cranking up the torsion bars? I'm looking to raise the front 3/4 to 1" to get rid of the "jacked up" rear end look. I dont have access to a floor jack right now (mines shot) and i was just wondering if its really necessary to take some of the tension off before cranking.
Thanks in advance for any help.
Old Mar 25, 2007 | 04:22 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: t-bar crank? again
I think it is easier on everything from the truck to your tools......
Old Mar 25, 2007 | 04:26 AM
drperry's Avatar
Might be a good workout if you don't lift the truck...
Old Mar 27, 2007 | 09:58 PM
4low4lyfe's Avatar
4low4lyfe is an unknown quantity at this point
Is there a way to do a t-bar crank without buying those $100 torsion bar keys. They look like a socket thats it. Just wondering. if there is a way could you help me out.
Old Apr 1, 2007 | 02:46 AM
CrazyJ's Avatar
Thanks for the quick replys guys.
I decided to try it without the jack... Cranked up easy as pie. I was really suprised.
Old Apr 1, 2007 | 02:49 AM
CrazyJ's Avatar
ORIGINAL: 4low4lyfe
I'm new to blazers. I have no idea what a torsion bar key is. I just used a 18mm socket to crank the bolts in to raise it. Crank them out to lower.
Old Apr 1, 2007 | 01:18 PM
Arthur's Avatar
Arthur is an unknown quantity at this point
Ok torsion cranking does not need a key... it is really really easy and shouldnt take you more than 15 minuets... Look along your frame near the front door and follow that long black pole as far as it goes back... when it stops you will see a bolt that is not tightened all the way... clockwise tightens it to raise the front end... be sure to crank the bolts on each side equally... all you need is an 18 mm socket
Old Apr 1, 2007 | 07:35 PM
coplinb's Avatar
coplinb is an unknown quantity at this point
is it bad on your suspension to crank the t-bars? ive never looked into it, but if it will give me some clearence, why not right?
Old Apr 4, 2007 | 03:37 PM
a_tack's Avatar
I wouldnt reccomend it for a DD simply because it stiffens the ride and is hard on stock ball joints and related gear..
Old Apr 27, 2007 | 09:02 PM
greenblazer's Avatar
greenblazer is an unknown quantity at this point
I cranked mine in the front to match the rear which i axle swapped. Front end has lasted pretty decent
Buddykitchen
Dec 10, 2016 06:37 PM
gatelocked
Feb 28, 2011 04:52 PM
g_mike
Aug 22, 2010 02:46 PM
KRUSHER
Jan 2, 2010 07:25 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
