Suspension Tech Have a question about modifying your suspension? Ask it here.
torsion bar how-to?
Old 04-21-2006 | 08:39 PM
sledneck16's Avatar
sledneck16 is an unknown quantity at this point
Default torsion bar how-to?
[8D] Looking to gain a little bit more clearance for my aftermarket tires---how exactly would I go about that? thanks very much--and i did try the search button to no avail []
Old 04-22-2006 | 02:55 PM
91_4_Door's Avatar
91_4_Door is an unknown quantity at this point
Default RE: torsion bar how-to?
different keys for the torsion bars but i may be wrong.
Old 04-30-2006 | 11:33 PM
BlaZeR FXB1581's Avatar
BlaZeR FXB1581 is an unknown quantity at this point
what does it mean "different key"?
Old 05-01-2006 | 02:24 AM
Hanr3's Avatar
Keys are what the torsion bas slides into under the drivers seat. There should also be a bolt under the key, crank it up some. Altough this will change your alignment, stiffer your suspension and put more strain on your cvs.
Old 05-07-2006 | 08:15 PM
BlueBlazzin's Avatar
BlueBlazzin is an unknown quantity at this point
Sorry to thread jack but this topic just reminded me of a question. To lower a 4 wheel drive blazer could you use springs to lower the front or do you have to use the torsion keys to do that type of thing.
Old 05-07-2006 | 08:48 PM
sledneck16's Avatar
yea dont worry about it---i got her figured out---my truck is lifted about 1.25' up front now. rides and looks way better! [8D] i would assume you could back off the torsion key bolts to and extent--but your ride will get softer--i would go with indexed keys (i would but im saving for bigger wheels and tires first--then its a 3 inch lift )
Old 06-05-2006 | 04:58 PM
dg94_4x4's Avatar
dg94_4x4 is an unknown quantity at this point
ORIGINAL: BlueBlazzin
Yuo have to use the torsion keys. 4wd s10 blazers dont have front springs.
Old 07-26-2006 | 12:30 AM
djremix's Avatar
djremix is an unknown quantity at this point
I just dropped my 4X4 3.5"-4" in front and 5" in the back. Used 4" blocks in the back and I ride a set of GABRIEL air shocks so when deflated gives me about 5" in the back. For the front, installed a pair of Nitro-Drop shocks, removed the torsion key bolt and block (for those of you who know how a torsion key works) and I built a plate, welded on the crossmember under the torsion key, and installed a bolt through that new plate...fully adjustable suspension in the front from 1"-6"...
Here's a link to the plate system used on my Blazer, basically same thing as the kit I used but mine is homemade... much easier that flipping your torsion key or replacing with aftermarket key...I basically did mine...for FREE. Just used scrap 3/8" metal plate, welded to crossmember, drilled and tapped, then used a 7/16" Grade 8 bolt to lift the stock torsion key to desired height...
www.proper-design.com
I am riding 2001 Camaro SS wheels 17X9...I do have all 4 wheels, I just got a blowout on one of the back tires...new tires coming VERY shortly. The front is a bit too low for me right now...I am sitting on the bumpstop (or whatever is left of the 1/2" I didn't cut off). I will be lifting it up about 1" or so just so I have no wheels gap, otherwise it rides real rough and I have mad camber and my new tires won't last!
[IMG]local://upfiles/2816/B6E21CE606914DA29718991A20916F21.jpg[/IMG]
[IMG]local://upfiles/2816/A6263EA777064DAB8C2208A126587E8F.jpg[/IMG]
[IMG]local://upfiles/2816/45BDDE0D668C4AD9A344F7032928DE43.jpg[/IMG]
Old 07-26-2006 | 12:54 AM
jagblazer01's Avatar
dude dj ur truck looks nice.
Old 07-26-2006 | 01:04 AM
djremix's Avatar
Thanks! it does look good but it rides rough. I will be taking care of that shortly! I'll lift the front about 1" and replace the destroyed bump stops and the ride will be a lot better. I'll put 1" bumpstops instead of the like 4" factory ones!
Quick Reply: torsion bar how-to?
