Torsion keys?
4wd front suspension use torsion bars up front yes.
To the original poster, are you attempting to lift the truck by cranking the torsion bars? If so, your ride will be worse... Also, the wear on the balljoints will be increased...
my front end sits 2-3 inches lower than the rear, so i want to level it up. and how is it that this would put more wear on the joints if was designed to be at that hieght to begin with? My rear end sits 8 1/2 above the tire (from tire to edge of fender) and the front is 5 1/2 inches (from tire to edge of fender)
If you are restoring it to stock height, it won't. If you are raising it up from stock height, you will be changing the angles and putting more stress on the components, causing them to wear out faster.
But you don't need aftermarket keys, just a jack, jackstands and a rachet.
