Suspension Tech Have a question about modifying your suspension? Ask it here.
Torsion keys?
Old Jun 21, 2007 | 07:03 PM
sasquatchfound's Avatar
sasquatchfound is an unknown quantity at this point
Default Torsion keys?
Can some one help me with a link to were i can get a set of torsion keys. I had my bars checked out and truckaline siad they are good. so I want the keys to torque the front.
Old Jun 21, 2007 | 07:11 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
Default RE: Torsion keys?
You can get them on ebay if you really want them.
You do know that you should be able to crank your t-bars within reason with the stock keys right?
Old Jun 22, 2007 | 07:25 AM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
All you need is an 18mm socket...
Old Jun 22, 2007 | 09:07 PM
I was told that after market torsion keys will keep the front from sagging. Or is this wrong?
Old Jun 23, 2007 | 01:52 AM
*Old_School*'s Avatar
*Old_School* is an unknown quantity at this point
These trucks have torsion bars for the front suspension?
Old Jun 23, 2007 | 05:38 AM
4wd front suspension use torsion bars up front yes.
To the original poster, are you attempting to lift the truck by cranking the torsion bars? If so, your ride will be worse... Also, the wear on the balljoints will be increased...
Old Jun 23, 2007 | 11:33 AM
my front end sits 2-3 inches lower than the rear, so i want to level it up. and how is it that this would put more wear on the joints if was designed to be at that hieght to begin with? My rear end sits 8 1/2 above the tire (from tire to edge of fender) and the front is 5 1/2 inches (from tire to edge of fender)
Old Jun 23, 2007 | 11:37 AM
If you are restoring it to stock height, it won't. If you are raising it up from stock height, you will be changing the angles and putting more stress on the components, causing them to wear out faster.
But you don't need aftermarket keys, just a jack, jackstands and a rachet.
Old Jun 23, 2007 | 11:45 AM
will i be able to torque the front enough to match the rear, i mean 3 inches is alot right?
Old Jun 23, 2007 | 01:52 PM
How is it that the front is 3" lower than the rear to begin with... Have you raised the back? If not, your torsion bars may be weak up front.
