Suspension Tech Have a question about modifying your suspension? Ask it here.
Vehicle Height??
Old Aug 3, 2006 | 10:20 AM
Aquahallic's Avatar
Aquahallic is an unknown quantity at this point
Default Vehicle Height??
Ok folks.. here's an easy one.... I was having that pulling problem and before I dug into it and foundout it was a bad tire. I let the mechanics try to troubleshoot it down and in the process they dropped the frontend of my 95 Blazer down some. I know it was too high but I think they may have taken it down too low now. Can someone tell me about how this thing is supposed to ride? Maybe a pic that I could look at so I can see how the trim stripe should matchup to the ground?? Also when I go under there to bring it back up some. Am I going to need any special tools to crank up these torsion bars? Or do I just use my normal air ratchet, and is it a normal bolt/nut or is it a weird torx or something like that? ALSO do I use something to clamp those pre-loaders down then turn the bolts.... or do I just start crankin' on the bolts and draw them down???
Thanx for the help...
Old Aug 9, 2006 | 11:39 PM
vic's Avatar
vic
vic is an unknown quantity at this point
Default RE: Vehicle Height??
na ur never to low
Old Aug 12, 2006 | 03:10 AM
sledneck16's Avatar
sledneck16 is an unknown quantity at this point
Nah its real simple 17mm socket (i think) and a decent ratchet. --as for ride height just make the frame rails level with the ground and that should be fine--it will settle after 20 or so miles so set it a little high.
wgg
Aug 29, 2011 11:30 AM
dougg01
Lifting Tech
19
Jan 21, 2010 02:48 PM
Kaffeene
Tires and Wheels
Mar 19, 2007 08:07 PM
a_tack
Headers, Intake, & Exhaust
Oct 22, 2006 04:44 PM
DetroitMuscle
Suspension Tech
Oct 10, 2006 08:53 AM
