Suspension Tech Have a question about modifying your suspension? Ask it here.
what axle
Old Aug 19, 2006 | 04:23 PM
mikehillis1@yahoo.co's Avatar
mikehillis1@yahoo.co is an unknown quantity at this point
Default what axle
what type off front axle will fit a 95 blazer and what can i get it off
Old Aug 19, 2006 | 04:27 PM
tommyd's Avatar
tommyd is an unknown quantity at this point
Default RE: what axle
are you talking a solid axel or new half shafts? solid axel you can make almost anything work. you may need to cut the axel tube and have new axels made but pretty much anything will fit. Just make sure you have the same gears front and rear or you will have problems
Old Aug 19, 2006 | 04:29 PM
I think he wants something that just bolts up. You'll need an axle from any s-series 4wd... I'm not sure of the year ranges, but any junkyards in your area will be able to do a cross-reference and let you know. You will need to figure out your axle ratio (RPO code from in the glove box) and match up the replacement axle.
chowell
Mar 6, 2021 09:47 PM
thrandall
May 3, 2013 04:54 PM
blajeans
Jan 9, 2013 12:58 PM
LucasMI
Jan 2, 2012 02:15 PM
jmaynard
Jul 12, 2011 01:03 PM
