what axle
are you talking a solid axel or new half shafts? solid axel you can make almost anything work. you may need to cut the axel tube and have new axels made but pretty much anything will fit. Just make sure you have the same gears front and rear or you will have problems
I think he wants something that just bolts up. You'll need an axle from any s-series 4wd... I'm not sure of the year ranges, but any junkyards in your area will be able to do a cross-reference and let you know. You will need to figure out your axle ratio (RPO code from in the glove box) and match up the replacement axle.
chowell
Mar 6, 2021 09:47 PM
blajeans
Jan 9, 2013 12:58 PM
jmaynard
Jul 12, 2011 01:03 PM
