Suspension Tech Have a question about modifying your suspension? Ask it here.
what size fits
Old Feb 28, 2014 | 09:15 AM
Blazed1488's Avatar
Blazed1488 is on a distinguished road
Default what size fits
i bought a 2.5 inch rough country lift for my 03 what size tires does it clear?? soon as the weathers warm ill be putting it in
Old Feb 28, 2014 | 11:45 AM
Diaita's Avatar
31" tires on factory offset wheels. They will still rub the frame slightly.
Old Mar 1, 2014 | 06:16 AM
Blazed1488's Avatar
thanks do you kbow what the max width is?? i plan on putting them on just some cleaned up junkyard steels
Old Mar 1, 2014 | 09:09 AM
El_Beautor's Avatar
You should be able to fit 31x10.5x15" tires on factory 4x4 rims without rubing the body, but you may rub the frame. If you go with lower backspaced rims you won't rub the frame but you might rub the back of the front fender. If you do you can either trim that area slightly, or go with a body lift to get more tire clearance.
The funny thing with the Blazers is there's lots of variance between individual trucks. I'd say you should be reasonably safe to go with 31x10.5's, and just know that it might take a bit more work to ensure that you don't rub. You really won't know for sure until you install them and test drive. You could always pick up a cheap set of tires and rims off Craigslist just for test-fitting before spending a big chunk of money on new rubber.
Old Mar 5, 2014 | 10:20 AM
Blazed1488's Avatar
awesome thanks fellas
mtmtntop
Sep 23, 2011 09:19 AM
91v10noob
Jul 23, 2010 04:22 PM
70L78
Apr 5, 2010 06:48 PM
Joemakerman
Mar 19, 2010 11:09 PM
dinar blazer
Feb 23, 2009 12:06 PM
