Will it work ??
Ive been looking around and thinking about the add a leaf springs to lift my blazer back to where it should sit and thinking about getting some shackles to go on the back leafs to give me an extra 2" lift on the back !!
But would i get enough lift on the front by adjusting the torsion bars to make it look level and correct ?? Is there any add a leaf springs that i should stay away from or any that are good and will lift my sagging leaf springs to where they should be.
Thanks
But would i get enough lift on the front by adjusting the torsion bars to make it look level and correct ?? Is there any add a leaf springs that i should stay away from or any that are good and will lift my sagging leaf springs to where they should be.Thanks
I don't have any advice on brand or type of add-a-leaf (short vs long) but the torsion bars shouldn't be cranked more than about 1-1.5". Depending on how much your rear springs are sagging, 2" shackles and add-a-leaf might lift the rear too high to get the front to match.
A tbar crank pushes the control arms down to gain height but since the front differential and axle aren't being lowered, the CV axles, balljoints and tie-rods all have to work at steeper angles which can cause them to wear out faster than normal.
thats what is done to mine and i think it sits pretty nice i bought it w/ tht done but im puttin 31/10.50/15 under it today and ill post pics of it w/ the tires later but heres a pic as it sits. hope it helped
Thanks
P.S. I 2nd what mdehoogh said in his post
Thankyou for the replys. Its told me to leave the shackles for now and just concentraite on the AAL and the shockers. What are pro comp like ? P.S Im wanting to get 31x10.5x15 tyres on mine when im done.
Just another question before i buy some shocks,.What type are the ends on the 2000 blazers ? Are they eyelets on both ends or 1 eyelet and one bar pin ?? Mine is a UK model !! Not sure if it makes a difference.
Thanks
Thanks
i just put a set of cooper discovery s/t's on mine with about 65% tread left and i rub on the driver side at the bottem of the wheel well gives it a nice hight and everything and i didnt see to much of a drop in my mpg either anyways 31/10.50/ are a squease w/o a lift and if it agressive you will prolly have to do some trimming
thanks! and yea its how i bought the truck originally thought it was lifted w/ the shackle and t-bar crank like your talking about but when i got under it for the tires it looks stock.... iv heard that some of these will clear 31's stock bc of the height guess some sat higher i guess i just got lucky on mine if you look at my photos you can see how it sat on my 245/70's and see it sits higher then most. try and compare yours to it because you will prolly have to do something because my 31's are about 60% i got them used so new 31s are gonna rub like mad! without the shackle and tbars cranked other option would b a 2'' BL whick on some still requires some trimming.
hope it helped!!
hope it helped!!
