15"x7" with 4" backspacing on 4x4 S10
Like everybody else I'm looking for new wheels for my 1994 Blazer S10 4x4, and I have found some Rock Crawler series 99 15x7 4"BS, but from what I've read nobody seems to think these will fitt without rubbing in the front?
Everybody just replys: "You might have some rubbing"
Isn't there anybody on this forum running with lower ET rims then the stock ET+60mm (6"BS) on a stock car? (no lift, no cut-outs)
I'm gonna use the stock 235/70/15
You should be ok if you use the stock size tire and don't do any hard wheelin or curb jumpin. I had the same size, style and offset wheels on mine with 31s with a t-bar crank and shackles, but I rubbed so I took a sawzall and a big hammer and did some friendly persuasion lol
i have some rims i threw on, i would like to know what backspacing they have and what width they are, im guessing they are 4 or 4.5 bs and maybe 8 wide i could be very wrong, all i know is that my tires swell out a tiny bit unless thats just the tire type and they sit out of the fender about 2 inches.
Looks good.
How is it to drive with those wheels? any rubbing?
I have considered to go for maybe 8" wide wheels in the back, with the same backspacing as the 7" in the front to get the rear wheels a littlebit further out, But im not sure if the 4wd is very sensitive to different front/rear tire diameter?
i might get 30's later but rite now all i got is the p23575r15 and they just barely clear in the front,and i mean just barely!
im looking into new rims now though just want some black ones but the same size
Looks good.
i am about to buy new rims that are 15x7 and 4.5bs, i want my tires to stick out of the fenders alittle but did you have a problem with the rear tires not sticking out as far. i did and i put spacers on and im not a big fan of them, but now all my tires stick out the same and it looks good. i want to take the spacers off though, so i just wondering what size rims should i get for the back to make up for the spacers? can i just get the 15x7 and run a little wider of a tire or get 15x8 for the back or just get 4''bs for the back and 4.5 for the front? any help would be very apreciated , oh by the way i am just running p23575r15s on stock 4x4 height no lift.
