15"x7" with 4" backspacing on 4x4 S10
Old Oct 5, 2010 | 11:50 AM
S.Hafsmo's Avatar
S.Hafsmo is on a distinguished road
I dont remember the difference inn width front vs rear wheels, but i seem to remember that the front wheels is about an inch further out then the rear wheels?
If it is one inch difference then a one inch lower backspacing would put the wheels equally far out in the wheel arch. 4.5" BS in the front and 3.5" BS in the rear, thats if the wheels are the same width though.
Another option would be to use 8" width and 7" in the front, and both wheels with 4.5" BS. But then you might encounter a problem with getting the same diameter on the tires as the e.g. 235/75/15 tires would be streched a bit on the 8" rim vs the 7" rim.
Old Oct 5, 2010 | 10:19 PM
bigjon1's Avatar
bigjon1 is an unknown quantity at this point
What I currently have for wheels are stock 2wd sonoma wheels. They are 15x7 with I believe 4.5" backspacing. I really can't tell any difference as far as sticking out.
The 8 in rim would still be fine for a 235/75/15. However the problem would be that you couldn't rotate tires front to back with that setup, only side to side.
But hey, it's your ride, do what you like, not neccesarily what other people think you should do and in the end you will be much happier with the result.
Old Oct 6, 2010 | 04:28 PM
wills-07's Avatar
wills-07 is on a distinguished road
Question
i think i am going to go with these http://www.4wheelparts.com/Wheels/Ro...pn=PCW152-5762
they will work right? what does Max Load=1600 lbs mean
Old Oct 6, 2010 | 10:45 PM
bigjon1's Avatar
Those should work fine and look really good. Max Load = the maximum amount of weight that the wheel can support. So in other words with 4 1600lb max load wheels, equalling out to 6400lbs distributed among the four, they should hold up to the weight of your blazer and anything you can put in it/ on it/ without failing
Old Oct 7, 2010 | 02:53 PM
wills-07's Avatar
Angry
thanks, think im going to wait till spring no sence putting them on for just a month or so. stupid salt and snow - the angry face is cause the winter i cant get rid of it now lol sorry
Old Oct 7, 2010 | 05:36 PM
bigjon1's Avatar
Lol I know what you mean about the winter. No need to be sorry, to be honest I didn't even notice it lol
Old Nov 7, 2010 | 08:01 PM
AndrewPetersV's Avatar
AndrewPetersV is on a distinguished road
So does anyone know how much the front wheels stick out from the rear? I would assume people would know as some have ordered spacers/wheel adapters to fix this issue.
Old Nov 8, 2010 | 04:17 PM
wills-07's Avatar
1.5 inches i bought wheel spacers match pretty well
95blazerlt
Tires and Wheels
Sep 25, 2013 08:48 AM
matt9589
Tires and Wheels
Feb 10, 2013 06:46 PM
_HeC_
Lifting Tech
Oct 5, 2011 06:53 PM
02 jimmy
Tires and Wheels
May 10, 2009 06:12 PM
superdaveidaho
Tires and Wheels
Apr 21, 2008 09:14 PM
