17in wheels on 98 4x4
Old Mar 18, 2013 | 06:39 PM
arroyo-blazed98's Avatar
arroyo-blazed98 is on a distinguished road
Default 17in wheels on 98 4x4
anyone running any 17x8s on a 4x4?
what will fit? max width on a 17 on stock suspension and height?
any pne have pics of 17s on mud grip tires on a 98 4door?
please post pics to help me decide on my size to order from summit.....
thanks all
david
Old Mar 18, 2013 | 10:26 PM
LeWhite's Avatar
My 4dr 2wd has 18x7.5 rims and uses tires in dirtspeak of 28x9.5. Truck is lowered 2" nothing rubs full lock full bump. Hope that helps
Old Mar 19, 2013 | 09:16 AM
El_Beautor's Avatar
You need more information to answer your question. Do you have specific rims in mind? What is the backspacing/offset of the rims you want? What size of tires are you hoping to run?
Rim height is much less relevant than rim width, backspacing, and the tire height and width. You can fit up to about a 30" tire, with factory backspacing (6") on the rim with no lift, but you may rub a bit with a 8" wide rim. If your rims have 4.5" or less back spacing (more common in aftermarket taller rims) and are 8" wide then you will probably rub at stock height with anything bigger than a 28" tire, and maybe even then. Without lifting I doubt you'll be able to run anything wider than a 255 series tire, and may be better off sticking with a 245 series.
Old Mar 19, 2013 | 03:34 PM
rexazz2's Avatar
if you go to tirerack.com it will do a mach up of different sizes
lannon_j
Tires and Wheels
Apr 7, 2014 06:23 AM
95blazerlt
Tires and Wheels
Sep 25, 2013 08:48 AM
huntersblaze
Tires and Wheels
Jun 20, 2009 04:39 PM
isenegger
Tires and Wheels
15
Oct 9, 2007 03:40 AM
