24 inch rims advice
Old Jan 26, 2010 | 10:25 PM
old skool luvr's Avatar
Originally Posted by BeatBox124
Thanks. Last time i checked he wanted to know if they wheels and tires would fit! Im pretty sure HE WANTS TO TURN too, if the width of the wheel is wider than 8.5 your tire is gonna hit on the frame before you have the wheel all the way turned.
I was saying unless u want to spend acouple thousand dollars on a "custom made" set of wheels you only have a few 24in wheels to choose from before they cost way too much....
ok, we were on the same page (just didn't want to assume what you were talking about).
Old Jan 27, 2010 | 10:29 AM
BeatBox124's Avatar
BeatBox124 is on a distinguished road
no problem
Old Jan 28, 2010 | 02:26 AM
MTopper's Avatar
quick question for you guys, i'm new on this forum but learning fast. with the blazer (mine is a 2004 2dr 2wd) the stock bolt pattern is 5x120.65mm, there aren't many options for that size anywhere. is it possible to run the 5x120mm pattern and not cause any damage to your truck? i'm a noob (or nube depending on who you are haha) in the wheels department. i want to run either 18s or 20s, depending on if i lower my truck at all.
fordnmarion
Tires and Wheels
Sep 9, 2010 12:40 AM
Keeler
Lifting Tech
22
May 29, 2010 03:53 AM
blazinUP
Tires and Wheels
May 14, 2010 08:06 PM
erik102207
Tires and Wheels
Dec 7, 2007 06:15 PM
