2wd Swirls on a 4x4
Old May 14, 2007 | 08:32 PM
TheDesertFox's Avatar
TheDesertFox is an unknown quantity at this point
Default 2wd Swirls on a 4x4
If i got 2wd s10/blazer swirl rims and mounted my 30's on them and did a t-bar crank do you think i'd still be rubbing in the front? My truck has no lift btw.
Old May 14, 2007 | 09:13 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: 2wd Swirls on a 4x4
Most likely. I put 30's on 15x8" rims with 4" backspace and they rubbed on the bottom of the fender. Nothing a little trimming couldn't fix.[sm=devilgrin.gif]
Old May 15, 2007 | 09:35 PM
Yea hopefully with a t-bar crank it shouldnt be as bad. And with a little trimming I should be good to go!
toyota83
Feb 7, 2010 03:04 PM
dgh91
Lowering Tech
Jul 13, 2009 09:59 PM
bravadaAWD
Jun 22, 2009 08:10 AM
chris015
May 27, 2009 11:10 AM
1fastls1ss
Tires and Wheels
Aug 31, 2008 05:25 PM
